Old 03-21-2006, 09:54 PM   #1
mkIIruckusbass
mkIIruckusbass is on a distinguished road
Default no start no voltage
Here is where I am at. I have a no start condition. I have dropped the fuel tank to change the fuel pump. While the tank was down I figured I would check voltage w/ the key on. I get no reading. I mistakenly grounded the positive terminal while putting in the battery a while back, since then it has not started. Is there a circuit breaker, in-line fuse or something I could check? Help I am at my wits end. Thanks for any help.
mkIIruckusbass is offline   Reply With Quote
Old 04-08-2006, 06:40 PM   #2
hangsupra
check all your fuses first.... and replace all the broken fuse first. after replace all the problem fuse. try to put the key on n turn till the ign. on but dont start the car. and see if it work. if it work then try to start the car. if the car crank and wouldnt start or it start and die in awhile due to a brakelight comes on the cluster. you need to replace your alternater. cause thats what i do on my way back in the day when i first got my mk2. hope this work. want to know more email me @ rare-rider@hotmail.com and i give you more info. where to check n do...
Old 04-10-2006, 12:06 AM   #3
midwestmk2
midwestmk2's Avatar
If it wont crank or no power to the rest of car then you have burnt your fusable links in the fuse box..
Old 04-10-2006, 11:34 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
replace the EFI fuse in your fusebox
Pics of my build.
Do a diagnostic first!
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
