#1 |
When I go in reverse when I start the car cold it grinds real bad. Sounds like the driveshaft rubbing the tunnel. It also does it just a bit while braking. I can't find any signs of where it's grinding though. When the car has been driven a bit it doesn't do it, maybe just a bit. Never going forward. Does this sound like a carrier bearing?
#2 |
Nope but it sounds like the gear set is about to let go or the spider gears in the diff..Mine was doing that and i just swaped another diff in..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!! http://www.cardomain.com/ride/858848/2 |
Thread Tools | |
Display Modes | |
1986 Turbo Automatic Transmission Rebuild? | professorbob | MKIII Supra | 2 | 01-26-2012 01:06 AM |
86.5 auto transmission removal HELP!!! | elmer | MKIII Supra | 13 | 04-06-2010 10:41 PM |
Should I try to rebuild my transmission, or leave it to experts? | Busted Knuckles | Non-Generation Specific Questions | 1 | 04-15-2008 01:20 AM |
87 MKIII transmission Problems | phzi | Non-Generation Specific Questions | 1 | 06-26-2007 01:49 AM |
Blown transmission | 1985Supra | MKII Supra | 2 | 01-31-2007 07:56 AM |
