Old 05-29-2006, 07:28 PM   #1
cooley346
cooley346 is on a distinguished road
Default grinding in reverse, not the transmission
When I go in reverse when I start the car cold it grinds real bad. Sounds like the driveshaft rubbing the tunnel. It also does it just a bit while braking. I can't find any signs of where it's grinding though. When the car has been driven a bit it doesn't do it, maybe just a bit. Never going forward. Does this sound like a carrier bearing?
cooley346 is offline   Reply With Quote
Old 06-02-2006, 02:24 AM   #2
midwestmk2
midwestmk2's Avatar
Nope but it sounds like the gear set is about to let go or the spider gears in the diff..Mine was doing that and i just swaped another diff in..
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
87 MKIII transmission Problems phzi Non-Generation Specific Questions 1 06-26-2007 01:49 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
