Old 05-10-2005, 05:45 PM   #11
Vanbao
Guest
Posts: n/a
Please help.
I am new here and I am in desperate need of some expert help. I own an early 1986 Supra which gave out on me while I was driving it on the freeway 2 weeks agao. What happened was that out of the blue while it was running nicely, it started choking and loosing power. Fortunately, I was able to get it to crawl off the freeway to a safe place to park. From that point on, I have not been able to get it to run. It would idles okay but if I step on the gas peddle, the engine would loose power and dies. My friend suggested that I should check for cracks and vacuum leaks . So I checked the air intake hose (the hose that is connected to the air filter and the air flow meter) and did not see any cracks. I also replaced the existing airflow meter with a different one from a wrecking yard. Unfortunately, that did not seem to make any difference. I checked the wires connecting to the airflow meter and found it to be working. I say it is working because when I unplugged it while the engine was idling, the engine would died. Some people also suggested that the problem could be the throttle sensor. I don't know how to find out if this sensor is working or not. However, when I unplugged the wires connecting it while the enginine is idling, nothing happened. The engine continued to idle. From this fact, I am thinking that the throttling sensor might be bad but I am not sure.
Other suspects could be the gas filter or the gas pump. What is strange is that when I applied the gas very slowly, then the engine would rev up and the rpm increased to a certain point. Tthen the engine would choked and lose power again. When let go of the gas after that, the engine settled back to idling.
During all these, the check engine light came on.
This is an old car I have bought when I started going to college. I don't think it is worth taking it to the dealer for repair. Thus, I am trying to figure out what the problem is and repair it myself if it is not too difficult.
Please help me if you know what is going on with my car.
Thank you so much in advance.
Old 05-10-2005, 09:58 PM   #12
KingDiamond
hey vanbao your best bet would be to put that into a new topic, you'll get more attention to your problem that way. Some people don't like tryng to answer and read one persons problem, and then in the middle of the same post a new topic pops up from another user about a different car.
Old 05-12-2005, 12:18 AM   #13
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
i have never seen a mkii so i wouldn't know and plus that thread is HUGE!! i might as well read the instruction manual.
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 05-17-2005, 09:23 PM   #14
hangsupra
Originally posted by suprra_girl@Apr 18 2005, 10:23 AM
the the engine sound particularly whooshy... like sucking alot of air in?
i would say you could have an intake manifold leak... try getting some engine start/ether/starter fluid (can't remember what you call it there) and spray that all around your intake manifold and vacuum lines
if your idle picks up in a certain place you spray you have found your leak... fix that then try the process again
you ign timing being advanced will also up your idle... i would suggest putting it back to 10deg and see how your idle is... just try moving your dizzy ever so slowly and see how you go
let us know how you get on
you only find air leak if the air sucking in only... if the air is leak n blow it out... the carbu. spray wouldnt help at all... it only help you when you find a leaking air that sucking in only tho.
Old 05-22-2005, 03:40 AM   #15
monkihead
monkihead's Avatar
1.the dont have a carb. 2nd if it has a vaccum leak, spraying carb cleaner or throttle plate cleaner will cause the idle to rise. doing so, lets you know if you have a leak. if you dont, nothing happens to the idle.
monique- better off dead
Old 05-29-2005, 05:17 AM   #16
hangsupra
well thats true. the idle will increase if you find the leak. hope you get to work.
Can my 1982 Supra be saved? CraiginCentral MKII Supra 1 02-06-2009 07:38 AM
Can my 1982 Supra be saved? CraiginCentral Non-Generation Specific Questions 1 02-06-2009 01:04 AM
