Old 06-29-2006, 02:55 AM   #1
mk2-1jz-:)
mk2-1jz-:) is on a distinguished road
Cool fuel pump
just wonderin im nearly completed my 1jz conversion will the standard 5m-7m fuel pump still work ok with my new motor? cheers
mk2-1jz-:) is offline   Reply With Quote
Old 06-29-2006, 04:44 AM   #2
midwestmk2
midwestmk2's Avatar
You might run but ill bet youll run into fuel cut on hard pulls..Your best bet is to upgrade to a Walbro255..
Old 06-29-2006, 05:37 PM   #3
mk2-1jz-:)
cheers for that..do you no how much there worth$$...and if i could buy from online as were i live in aus is a pretty small town and has NO turbo performance shop..but if they sell in aus ill prob be able to order from here tho..
Old 06-29-2006, 10:52 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
http://www.boostonline.com.au/shop_p...asp?prodID=610
i just googled that
or buy off ebay
Pics of my build.
Do a diagnostic first!
Old 06-30-2006, 06:12 AM   #5
midwestmk2
midwestmk2's Avatar
You can also get one from Aaron at http://www.rabidchimp.com/mk2sup_walbro.htm He will ship it to you..
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
Fuel Pump or what? Drack57 MKII Supra 7 11-28-2005 07:33 PM
