Just bought a 1985 Supra and the differential is leaking,,I found a 1986 supra differential but am not sure if they are the same?? I either need to put seals in the one I have,(and tighten it up a bit) or replace it. So far I have not found where to buy Parts for the differential! Any opinions on this subject would be appreciated greatly,,Thanks
well....the only way you can get part from is at the junk...its more cheaper than any where else...so yeah... oh by the way... they will fit on but you need... to change the drive shaft from the trainny to the rear end differential and also the 2short shaft from the side (left/right)....
1jz swap | 87-POSupra | MKIII Supra | 4 | 10-27-2008 03:34 PM |
differential swap or not | kkiepvvessau | MKIV Supra | 22 | 09-02-2008 01:55 AM |
Year to Year MGE Swap changes | Mr.Bojangles | MKIII Supra | 6 | 01-10-2008 07:44 PM |
1JZGTE swap question | supradaddy0803 | MKIII Supra | 1 | 04-12-2007 04:56 PM |
2JZ Motor Swap | MDellboy420 | MKIII Supra | 3 | 09-11-2006 06:19 PM |
