Old 03-13-2005, 02:20 PM   #1
yooper61_99
yooper61_99 is on a distinguished road
Just bought a 1985 Supra and the differential is leaking,,I found a 1986 supra differential but am not sure if they are the same?? I either need to put seals in the one I have,(and tighten it up a bit) or replace it. So far I have not found where to buy Parts for the differential! Any opinions on this subject would be appreciated greatly,,Thanks
yooper61_99 is offline   Reply With Quote
Old 03-16-2005, 11:26 PM   #2
hangsupra
well....the only way you can get part from is at the junk...its more cheaper than any where else...so yeah... oh by the way... they will fit on but you need... to change the drive shaft from the trainny to the rear end differential and also the 2short shaft from the side (left/right)....
1jz swap 87-POSupra MKIII Supra 4 10-27-2008 03:34 PM
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
2JZ Motor Swap MDellboy420 MKIII Supra 3 09-11-2006 06:19 PM
