Old 10-09-2006, 04:21 AM   #1
my 1984 celica-supra
my 1984 celica-supra is on a distinguished road
Default help please
i recently bought a 1984 celica/supra it sat for about 1 year had to replace fuel pump. But now when i come to a stop the throttle will not return back to idle unless i rev it up a few times. Also it looks like a cv joint cover in the front on the driverside which is leaking fluid badly feels like brake fluid but not sure. Any help would be greatly appreciated.
my 1984 celica-supra is offline   Reply With Quote
Old 10-09-2006, 02:17 PM   #2
supra1985turbo
supra1985turbo is on a distinguished road
Clean that side of the engine compartment with degreeser so you can see where the leak is. You might want to spary some carb cleaner in your throttle boddy to clean the butterfly and spray your lenkages to (spelling sucks). You also might want to try to put some Beramens B-12 in your full gas tank to clean your injectors out. You can get this at any parts store.
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
supra1985turbo is offline   Reply With Quote
Old 10-10-2006, 06:11 AM   #3
midwestmk2
midwestmk2's Avatar
That little cv booy you are talking about is the steering rack..So your leaking power steering fluid..
Old 10-14-2006, 10:54 PM   #4
thanks for the help i sprayed the butterfly and the linkages.That fixed the problem with the throttle.The power steering bood is cracked.Is that just a dust cover or does that actually hold power steering fluid?
Old 10-18-2006, 02:58 AM   #5
Mark's MKII
Mark's MKII is on a distinguished road
Thats just the dust cover, the seal in the PS rack is leaking
Mark's MKII is offline   Reply With Quote
Old 10-18-2006, 04:39 PM   #6
supra1985turbo
Glad I could be some help, but bad news on the MKII's you have to buy a new PS rack. Unlike the MKIII's youcan buy a rebuild kit. Sorry about the bad news!
Good news is that o'riely's can order them or could and the cost about $250 give or take a few $. I have the same problem with my MKII.
Old 10-19-2006, 01:38 AM   #7
hangsupra
when you get the job done... $$$ isnt the problem after all...
Old 10-20-2006, 12:33 AM   #8
84 celicasupra
84 celicasupra is on a distinguished road
just the seal can't be replaced? is the seal hard to get to?
84 celicasupra is offline   Reply With Quote
Old 10-20-2006, 11:43 PM   #9
well that sucks i guess i will be without power steering until i get that fixed.I was hoping it was just the boot causing the problem!But i guess it is never that easy. Thanks for the info. The other ? i had was my car smells like fumes when you are slowing down to come to a stop or like if u are getting off the interstate ramp. I had an 88 mr2 that did the same thing is this a common thing or may there be something wrong with the injectors,oxygen sensor or something like that?
Old 10-21-2006, 01:41 PM   #10
supra1985turbo
Dose it smell like gas? If so you have a fuel leak in your engine compartment. It is not tipical to smell fumes in the car unless you have a leak. If it dose not smell like gas you might have an exhaust leak near the engine. What kind of fuel milage do you get? You could also have a leaking injector. Pull your oil dip stick and spell the oil on it. If it smells like gas than you have a leaking injector. If you do might as well replace all 6. You can usally find them on ebay for the 5MGE. If not look for the ones for the 7MGE or 7MGTE. they are higher cc's and will fit like the 5M's injectors!
