Old 11-02-2006, 01:58 AM   #1
SupraBoy
SupraBoy's Avatar
SupraBoy is on a distinguished road
Default more questions....
ok so i have seen the thread where the guy talks about his own custom made pvc pipe intake and was wondering if anyone could describe how to do this and/or post pics...
it would be greatly appreciated...what are the up and downs of this...will it be better than the stock intake that came on my 1984 supra...thnkx
also when i start my supra it idles really low for a second....then it shoots up and then goes back low to where it almost dies...so pretty much i cant keep it at the right idle unless i have my foot on the gas right holding it there....what could cause this and how do i fix it
SupraBoy is offline   Reply With Quote
Old 11-03-2006, 02:33 AM   #2
hangsupra
i done few custom air intake pipe for my mk2... and also turbo pipe too...
well first of all... you need to have a bent machine... were you can bend the pipe... thats the first thing you need to do...
second... you need to measure n cut the pipe n bend it the way you want it to be...
about your idle problem...
one thing... maybe your idle is to low... i mean your degree on pulley... maybe way below normal... or maybe its way to high....
sometime you have air leak it does that too... i mean your air intake leaking somewhere....
and sometime your distributer not in the right mark.... i mean your rotor...
and sometime its your spark-plug too... it goes bad.... and it didnt have enough spark...
check this easy thing first....
Old 11-05-2006, 12:56 AM   #3
SupraBoy
SupraBoy's Avatar
i was wondering if there is ANYWHERE i can find the rear window louvers, not the hatch window...but the rear passenger windows...i saw a pic of a guy on celicasupra.com but i went back to find it and couldnt...they look kinda like this...but on a supra (http://www.accessconnect.com/images2/10486.jpg)...
any info would be great....thnx
Old 11-11-2006, 05:52 AM   #4
SupraBoy
SupraBoy's Avatar
alright so when my car is idleing there is a really quite sounding whistle type noise coming from the engine...and as you rev it up and put the rpms up....the whistle gets louder....what is this noise..any ideas....i will try and get a vid of it so you can here it....
Old 11-11-2006, 04:16 PM   #5
tone loc
tone loc's Avatar
might be air leak. get some carb or brake cleaner and spary your vaccum hoses with the car running. while your doing this have someone wacth the rpms and if it shoots up or down then you have a vaccum leak in that hose.
Old 11-12-2006, 04:26 AM   #6
midwestmk2
midwestmk2's Avatar
That whistling sound is actually is the sound of the air turbulence in the intake duct.. As the RPM increases the MAF flap opens to let in more air and makes the sound change pitch and sounds like it is a bad leak..
Old 11-12-2006, 04:27 AM   #7
SupraBoy
SupraBoy's Avatar
so is it suppose to make that noise or not...and how do i fix it
also are there any cheap engine mods to increas my speed a little...or just any cool cheap mods period...thnx...
Old 11-12-2006, 10:09 PM   #8
midwestmk2
midwestmk2's Avatar
Its suposed to make that noise..The only way to fix it is to use the entire stock intake system with the muffler and sealed airfilter box..
Old 11-19-2006, 08:03 PM   #10
hangsupra
those are my 7mgte custom made pipe n ect....
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
