Old 11-08-2006, 02:45 AM   #1
SupraBoy
SupraBoy's Avatar
SupraBoy is on a distinguished road
Default Exhaust
does anyone know any good sights to buy a good exhaust system from...preferably one with like no welding required...and maybe a header...any info would be great...
or should i just go to my local muffler shop and get it from them...
SupraBoy is offline   Reply With Quote
Old 11-08-2006, 09:23 AM   #2
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
Here ya go..
http://www.rabidchimp.com/mk2sup_cbexhaust.htm
Or do like me and have someone put you in a 2.5" piping all the way back from collector to muffler..No cat..No resonator..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
Old 11-08-2006, 03:39 PM   #3
SupraBoy
SupraBoy's Avatar
see i would do that except in washington you have to pass an emissions test...and it couldnt without a catylitic converter...otherwise i would
Old 11-08-2006, 05:03 PM   #4
Cool
you build a section of 3 " pipe to bolt on where the cat goes when you are not getting emissions tested.
Old 11-13-2006, 01:31 AM   #5
SupraBoy
SupraBoy's Avatar
ok...so ruling out a pipe from collector to muffler, can anyone recomend a DECENT(not looking for performance or racing, just need one other than the one that came on it in 1984) cat back system in the 200 dollar range
what about the pacesetter monza system?
Originally Posted by Toyotafanatic
Damn HONDAS, YOU HONDA GUYS SUCK, JUST GET YOUR DAMN SLOW, GIRL CAR OFF THE ROAD AND SAVE THE ROAD FOR SOME TRUE HORSEPOWER, SUPRAS FOR LIFE!
Old 11-19-2006, 07:39 PM   #6
hangsupra
i'm sure you can get all those item from your local auto part fo under $350 and its a peac header header and a bosal or something like that and it come with a direct fit.... no need to modification i mean no welding... it bolt right up....
and also performance and it also past smog inspection too.... its a stock item...
Old 11-30-2006, 03:59 PM   #7
kornkid
kornkid is on a distinguished road
go to www.935motorsports.com. they have quite a few options and offer a pacesetter system for under $200.
82 Ptype (6mgte project)
kornkid is offline   Reply With Quote
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Exhaust Cat Fitting Bill UK MKIII Supra 4 06-15-2008 11:32 AM
Dual exhaust, anyone? lifesnotfair MKIII Supra 13 12-22-2005 10:41 PM
