Old 11-29-2006, 05:44 AM   #11
edelmar417
edelmar417 is on a distinguished road
Default one more thing
does anyone know if the ecu needs to be reconfigured if i slapped on a turbo?
restoring with a touch of performance. future mountain carver.
genesis - 1:23 " and god said unto the canyon folk, turn fast, stop fast, then go fast. And the canyon folk agreed and it was all good."
edelmar417 is offline   Reply With Quote
Old 11-30-2006, 06:48 PM   #12
kornkid
kornkid is on a distinguished road
the ecu should be able to handle it just the way it is. the uprgraded rrfpr (rising rate fuel pressure regulator) should be enough to get it to run right. if you want to get more boost than 9 psi you would want to look into a super air fuel controller (safc) or the possibility of swapping in a 7mgte.
82 Ptype (6mgte project)
kornkid is offline   Reply With Quote
Old 12-27-2006, 01:58 AM   #13
brian leiser
brian leiser is on a distinguished road
save more money do the 7mgte swap ive gone down that 5m road.im a driveabilty guy.the 7m setup runs so much nicer.7m ecu designed to run a turbo charged engine. im 1jz powered now.words cannot describe how wild it is.well maybe not as wild as a bunch aisan hookers! lol
1jzgte
brian leiser is offline   Reply With Quote
Old 12-27-2006, 04:57 AM   #14
edelmar417
Default really?
what were your costs compared to the 5m beefy set up compared to the 7m swap? anyone that has done the swap?
Old 01-02-2007, 02:44 AM   #15
brian leiser
should be able to handle it???????do you know for fact! should be enough to get to run right!??????????only tell people if you know for fact cause if not guys like you dont know unless you built it and ran it to say yes this works.not what you replied to this guy lookin for solid information!
1jzgte
Old 01-03-2007, 08:41 AM   #16
edelmar417
Cool you know what
well my brain is pretty much fried from going back and forth on whether i should go turbo or not. since most people have done the 7m-gte swap and choose that over the 5m-gte conversion, i'll just save my money to do that. for now, just restoring the body and the car itself as my tag line says.
Old 03-23-2007, 05:13 AM   #17
83restomod
83restomod's Avatar
83restomod is on a distinguished road
just b prepared to spend 3-5k on a 7mgte swap. you can say im full of it but i wanted to do a low budget swap myself. like spend 2 grand but all the little stuff adds up fast. celicasupra.com will deff help. 5mgte's are cool and pretty rare but take some time to dial them in right. 7mgte swaps take just as much time and brain power. good luck
83restomod is offline   Reply With Quote
Turbo Charging mkiii supra supraflymk3 MKIII Supra 4 05-24-2008 03:11 AM
turbo charging suprabahamut MKIII Supra 0 02-19-2008 01:07 AM
