Old 04-19-2005, 05:52 AM   #1
eleazar515
eleazar515 is on a distinguished road
Has anyone here had any problems with their Mk2's ecu (car's computer)? My car has a little stutter in lower rpms. A while back I tested around a bit and found the ecu wasn't properly reading the tps (throttle position sensor). I tested the tps & it passed with flying colors. I checked out the readings from the ecu directly regarding the tps & it's readings were wacked. I thought about replacing it with a junkie but didn't want to bother with another old ecu if it was a common old-age symptom. Couldn't really afford a new ecu even if it was available, so I basically set-aside the whole bit and just have lived with it. I'm planning a pretty long drive in the near future so I'm trying to get her running as sweet as I can. B)
btw - anyone experimented with switching to electric fans? (someone who did)
eleazar515 is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
