Oil leak(s)
I am having a problem with an oil leak on the exhaust side of my engine from the front, it looks like it coming from the back of the water pump.
I have replaced the seal on the front of the engine behind the plate behind the cam gears, I do have the leaking cam seals and will be doing those soon. could this oil be coming from the cam seals, there is quite a lot of oil loss. Where elso could it be from?? its not from the cam box's its not the head or block. I want to fid out as much as I can about where it could be coming from befor I get into it as I have to remove the radiator to do this task (its in a hilux) Cheers, Matt |
yeah,the cam seals could be causing the leakage.i would clean it with a good degreaser and then keep an eye on it for a while to see if you can track down where it is exactl;y leaking so you are not wasting time and money
I have degreased it several times but cant find the exact place, I know the cam seals are leaking cause I have seen them leaking. I just need to know if there is anywhere else on the front\exahaust side of the engine that oil could come from.
Well I replaced both seals, they were brittle and came out in shattered bits. No more oil leaking which is a good thing.
Here is a clip of what the engine is in http://www.youtube.com/watch?v=sV6JPOZyJTU |
