Old 02-25-2007, 06:37 PM   #1
Number_Sixx
Number_Sixx's Avatar
Number_Sixx is on a distinguished road
Default 1984 Supra wheels
Hello all.......I would like some clarifications on the wheels that came on the 1982-84 Supra's. From what I understand is that these wheels that are standard issue on the P Type are 14x7 and later on the L Type are 15x6. Am I corrrect on the rim sizes?? Is there a name for those style rims?? Here is a pic of the wheels I am referring to.
Number_Sixx is offline   Reply With Quote
Old 03-03-2007, 12:42 PM   #2
Number_Sixx
Anybody in here know if those wheels can fit the LHD 1981 Corolla wagon??
Old 03-23-2007, 05:37 AM   #3
83restomod
83restomod's Avatar
83restomod is on a distinguished road
L-type wheel (82-84) 14 x 5.5", +27mm offset
L-type wheel (1985 only) 15 x 6", +20mm offset.
P-type wheel 14 x 7", +8mm offset
All have a 4:114.3 bolt circle/bolt pattern.
if the car has the same bolt pattern try it. just watch the off set of the wheels on the car. they fit on a AE86 if that helps.
83restomod is offline   Reply With Quote
Old 03-24-2007, 04:16 AM   #4
Number_Sixx
thanks for the info dude.
got these wheels about a week ago. Here they are on my wagon.
http://i80.photobucket.com/albums/j1...ixx/Supra4.jpg
Old 03-25-2007, 07:53 AM   #5
edelmar417
edelmar417 is on a distinguished road
Default offset
someone care to educate me about what offset means?
restoring with a touch of performance. future mountain carver.
genesis - 1:23 " and god said unto the canyon folk, turn fast, stop fast, then go fast. And the canyon folk agreed and it was all good."
edelmar417 is offline   Reply With Quote
Old 03-25-2007, 02:12 PM   #6
Number_Sixx
offset is the distant of the mounting pad from the centerline of the wheel. There are 3 types of offset, positive, zero and negative. Positive offset is when the mounting pad is more towards the street side of the wheel, zero offset is when the mounting pad is in the center and negative is towards the hub side or the brake side. Deep dish wheels are negative offset.
Old 04-05-2007, 03:13 AM   #7
edelmar417
Default BBS rims
i found some 4 lug bbs rims http://bmwpugetsound.com/vbb/showthread.php?t=34122
for the 4 lug isn't there 2 different versions of the 4 lug? and also, do you think they would fit on the 85 supra?
questions? comments? concerns?
Old 04-05-2007, 12:19 PM   #8
Number_Sixx
Those BBS mesh wheels lug pattern are 4x100.........the Supra's lug pattern are 4x 114.3 so those BBS will not fit.
Old 04-05-2007, 11:04 PM   #9
edelmar417
Default ok
thanks for the info.
Old 04-06-2007, 02:58 AM   #10
edelmar417
Default rims
i'm trying to find something like the BBS basketweave. the only thing close to it is the OM simmons locted here >> http://www.celicasupra.com/phase0.htm
i'm trying to find around the sizes of 16x7 in the front, and 16x8 in the rear.
i'm looking at the ae86 rims on ebay http://stores.ebay.com/sgmotoring_16...GS_W0QQfsubZ11
opinions? questions? concerns?
1984 Toyota Supra Repair Jake73 Non-Generation Specific Questions 0 12-09-2006 11:59 AM
