Old 02-06-2005, 05:28 PM   #1
82supraTT
82supraTT is on a distinguished road
Does anyone out there know of how to swap over the old 4x114.3 bolt pattern to the newer 5 lug pattern????? pleeeeeease help!!!!!!
82supraTT is offline   Reply With Quote
Old 02-19-2005, 06:16 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i wouldn't have a clue if you can do it on a mk2... but i believe there are kits out there you can get to do it
Pics of my build.
Do a diagnostic first!
Old 03-19-2005, 05:58 AM   #3
hangsupra
well....you can....but you need to do lots of modify tho...cause you have to change all the rotor n every....it hard tho.....i havent done to my mk2 yeah but i other friend who got the mk2 like mine....he convert to mk3 rotor so that he can upgrade the rims....so it took him awhile to get the job done....but i remember he said that he were modify or redrew the bolt tho...hope you can find some expt. to do it for you or take to a shop where they do automative custom to do it.....if there is one in where u live at...hope that give you idea....
Old 03-24-2005, 03:16 AM   #4
hangsupra
well...i just got a good news for you.... i got this info. for our mk2 that who wants to convert from 4lugs pattern tino 5lugs here is the info. that i found on website...
JDM
WIDE TREAD SPACER
for ACURA HONDA MAZDA TOYOTA
THICKNESS: 15mm
BOLT PATTERN: 5X114.3
HUB BOLT: 12X1.5
THIS PAIR OF 15mm THICKNESS GOLD ANODIZED BILLET SPACERS.
A pair runs about $115-130.... the bolt n every thing you need is also including...
i found this out on ebay... type in "JDM WIDE TREAD SPACER RX7 SUPRA LEXUS MITS T15 5X114.3" or you can type in item # 7962529894 n or you can also type in the seller name i think... seller name are wheel_choice hope this work...
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
7MGTE-7MGTEU conversion guide? ravenmaster MKIII Supra 1 02-17-2008 01:17 AM
Flip headlight conversion?!?! dannydavi MKIII Supra 3 03-18-2007 12:25 PM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
celica supra engin conversion supramadness MKII Supra 3 04-10-2006 12:00 AM
