Old 05-03-2005, 07:23 PM   #1
jerymi
Guest
Posts: n/a
my idle on my 85 supra runs between 1100 and 2000 back and forth. what can cause this and how do i fix?
Old 05-06-2005, 05:27 AM   #2
monkihead
SP58GT
monkihead's Avatar
were you able to check the isc valve??
monique- better off dead
Old 05-18-2005, 01:20 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
get some ether/engine start/starter fluid and spray it around your intake manifold, i think you may have a large leak there
does it sound like its leaking?
also moved to mk2 section
Pics of my build.
Do a diagnostic first!
Old 05-29-2005, 05:19 AM   #4
hangsupra
is your pulley set at 10* or close to 10*.. if you way off or to low it can happen to
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
HELP!!!!!!!.....1JZ wont idle!!!!! kuroi_tuki MKIII Supra 1 07-09-2007 12:41 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
