Old 05-29-2007, 08:51 PM   #1
supra210
supra210 is on a distinguished road
Default Help Engine cranks but wont start
I was drivin, messin with a ranger he took off and right as i hit the gas it died.
The fuel pump relay, circut opening relay, and resistor are all fine. replaced the fuel pump. still wont start. I know im gettin spark. What else could I check?
Someone HELP!!
supra210 is offline   Reply With Quote
Old 05-30-2007, 12:46 PM   #2
ssaskiksubucni
ssaskiksubucni is on a distinguished road
Check the rest of your fuel delivery system. the line could be clogged or something stupid like that. or you could have lost compression in your motor by messin with the ranger. a sudden spur of power on an older engine can blow gaskits and i've done it many a time, expecially on older cars. check for any leaks and if you can't find anything, check the throttle body. if you have spark and the motor won't crank, the next things are fuel and air.
hope this helps a little
ssaskiksubucni is offline   Reply With Quote
Car Cranks But Won't Start... Please Help Toyota87Supra MKIII Supra 3 04-12-2007 03:06 AM
Start up and engine dies. Drag0na5h MKIII Supra 12 01-14-2007 02:04 AM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
Engine still wont start 87 supra 7mge lilsmitty MKIII Supra 12 01-12-2006 10:53 PM
