Old 05-29-2005, 06:34 AM   #1
Guest
Guest
Posts: n/a
i got a 5mge n i turbo charge it. n i got the HKS SSBOV Blow Off Valve Sequential. where do i hook this blow valve to, to make the best blowing sound. is it between the afm and the turbo or sure i connect it on the piping that before the throutle body. where do i hook this up at to make it sounds nice.... n where do i connect the little vacuum lines on the back of the blow valve to. where do i connect that to. and my other question is that whats the highest psi i can boost on my 5mge motor. as right nowi boosting 6psi. and i want to know whats the max i can boosting on my 5mge. please help cause i dont want to get my 5mge bhg tho. so please help me asap alright. thanx.
Old 05-29-2005, 08:05 PM   #2
hangsupra
iono how you setup your turbo on your mk2 supra but i got the same blow off valve like you to. n i hook it up before the thortte body tho. need pix i show you mind...
Old 05-29-2005, 10:50 PM   #3
KingDiamond
Pics would be nice always looking to learn something new myself.
Old 05-30-2005, 10:23 PM   #4
monkihead
monkihead's Avatar
the vacum line goes to a port after the throttle body. to be on the safe side i wouldnt go more than 6psi. what octane rated fuel are you using??
monique- better off dead
Old 05-31-2005, 03:44 PM   #5
Guest
Guest
Posts: n/a
i not sure which vacum line are you talking bout... got pix that will be great. well.. i were using the mk3 injecter.
Old 05-31-2005, 03:57 PM   #6
hangsupra
you ask for the pix. here is the pix. alright. its kind of dark but if want more better pix let me know alright. thanx.
on the blow valvue pipe i do a custom made only. i made that from local muffler shop.
Old 05-31-2005, 04:51 PM   #7
Guest
Guest
Posts: n/a
well. thats how i setup my blow valvue to. but i dont know how come i didnt hear anything tho. i didnt hear my blow valvue blow at high rpm n also when i shift at high rpm also. i dont know why it didnt blow. arent your blow valvue blow when you shift at high rpm or when you change gear tho. let me know alright. cause i got a nice blow valvue n it didnt blow at all it suck. well beside that i did adjust the bolt on the back of the blow valvue to. n it still didnt do anything at all. so please help me. this is suck. no fun at all.
Old 05-31-2005, 07:49 PM   #8
hangsupra
i dont know bout ur then. but my blow valvue does blow at n rpm when i shift tho. i got my blow valvue brand new from japan. got it for $328 US dollar. hehe. but my was new tho. if i were u i look around n see if any one got the same blow valvue like you. and see if they will let me borrow for a test. n replace your old one n do a test see if thats the problem you need. if you put up a new one n still didnt blow then i think you do something wrong with your turbo piping. if you dot to work n your blow valvue did blow then i think your old one or the one you running on right now is busted. get a need one instead of the use one tho. hope this info. help you. let me know how you get to work alright.
HELP ON!! TURBO CHARGE MY 5MGE Guest MKII Supra 2 05-04-2005 04:25 PM
