Guest
Posts: n/a
i got a 5mge n i turbo charge it. n i got the HKS SSBOV Blow Off Valve Sequential. where do i hook this blow valve to, to make the best blowing sound. is it between the afm and the turbo or sure i connect it on the piping that before the throutle body. where do i hook this up at to make it sounds nice.... n where do i connect the little vacuum lines on the back of the blow valve to. where do i connect that to. and my other question is that whats the highest psi i can boost on my 5mge motor. as right nowi boosting 6psi. and i want to know whats the max i can boosting on my 5mge. please help cause i dont want to get my 5mge bhg tho. so please help me asap alright. thanx.
iono how you setup your turbo on your mk2 supra but i got the same blow off valve like you to. n i hook it up before the thortte body tho. need pix i show you mind...
Pics would be nice always looking to learn something new myself.
#4 | |
![]() Quote:
....all you need is a small taste of success and you will find it suits you.... monique- better off dead ![]() |
Guest
Posts: n/a
i not sure which vacum line are you talking bout... got pix that will be great. well.. i were using the mk3 injecter.
#6 |
you ask for the pix. here is the pix. alright. its kind of dark but if want more better pix let me know alright. thanx.
on the blow valvue pipe i do a custom made only. i made that from local muffler shop. |
#7 |
Guest
Posts: n/a
well. thats how i setup my blow valvue to. but i dont know how come i didnt hear anything tho. i didnt hear my blow valvue blow at high rpm n also when i shift at high rpm also. i dont know why it didnt blow. arent your blow valvue blow when you shift at high rpm or when you change gear tho. let me know alright. cause i got a nice blow valvue n it didnt blow at all it suck. well beside that i did adjust the bolt on the back of the blow valvue to. n it still didnt do anything at all. so please help me. this is suck. no fun at all.
#8 |
i dont know bout ur then. but my blow valvue does blow at n rpm when i shift tho. i got my blow valvue brand new from japan. got it for $328 US dollar. hehe. but my was new tho. if i were u i look around n see if any one got the same blow valvue like you. and see if they will let me borrow for a test. n replace your old one n do a test see if thats the problem you need. if you put up a new one n still didnt blow then i think you do something wrong with your turbo piping. if you dot to work n your blow valvue did blow then i think your old one or the one you running on right now is busted. get a need one instead of the use one tho. hope this info. help you. let me know how you get to work alright.
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
HELP ON!! TURBO CHARGE MY 5MGE | Guest | MKII Supra | 2 | 05-04-2005 04:25 PM |
