Old 11-29-2007, 06:41 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
maybe you got water in the spark plug holes i would missfire and lose power when i had that when i would almost reach 4-5k but i got a 7mgte might be different but i replaced mine and havent had a problem ever since or oyu might have a vacuum line unhooked or a leak check all your connection and compare to the tsrm to see if theyre the same
cyanide-is-a-way-out is offline   Reply With Quote
Old 12-12-2007, 09:36 AM   #2
jimmys86mkii
jimmys86mkii is on a distinguished road
that is true but you would notice it when the cars at an idle and you wouldnt really get any power id say get a chiltons and jump your system and see what the code reads out to be if it tells you its the air intake temperature signal then you may just need to change the spark plugs. and "IF" you do have water in the plug holes then when you change the plugs spray some ether down in the holes so that it will start right up.
jimmys86mkii is offline   Reply With Quote
Old 12-16-2007, 11:40 PM   #3
gpgtp_22
gpgtp_22 is on a distinguished road
Some misfires don't show up at idle and only occur under heavy loads. I would check plugs/wires first. You can load the engine and mist water on the wires with a spray bottle and listen for arching to check the condition of the wires.
gpgtp_22 is offline   Reply With Quote
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
