Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 08-24-2007, 11:45 PM   #1
Spudboy
Spudboy's Avatar
Default 7M Sensor locations
ADMIN EDIT: This is the USDM oil pressure sender, connector and boot.
What is this (shinny silver) 1st picture? Drivers right, lower front of block.
When I was disconnecting wires this plastic grey cap came off the "What is this" very easy. The wire and it's connector underneath doesn't make sense to me as to how or where it connects.
HTML code is On
