Old 11-13-2009, 11:06 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Locate the CPS with the cam pulleys as sown below, assuming you have already re-installed the can belt with the crank pulley set at zero (# 1 piston at top dead centre) and cam pulleys as in photo. Line up the hole and notch as marked with the red arrow on the CPS and insert into the head. You may find when the gear engages with camshaft helical gear the CPS shaft will rotate, I removing mine a few times to double check it hadn’t moved before nipping up the adjusting bolt. Its also worth replacing the O ring Toyota part # 90099-14018
018
Old 02-04-2010, 03:49 AM   #2
Then to set the spark advance, warm the engine up to normal operating temperatures and follow the instructions below:
EDIT: for some reason that attachment didn't work so well.... here's a link to the TSRM page on it.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
You MUST insert a jumper across T(E)1 and E1 in the diagnostic box when setting/checking the timing. Additionally, NO CODES can be present, the throttle MUST be fully closed and the A/C MUST be off... and the engine needs to be at normal operating temp. The timing is supposed to be at 10 degrees BTDC, the ECU will advance it further based on sensor feed back, it's not an old Chevy, advancing it further yourself will actually do NOTHING.
Old 08-03-2010, 03:06 AM   #3
More of the same
http://www.supras.com/06/techcenter/display.php?QID=85
Old 08-04-2010, 12:47 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
Nice pic on Green's link of the turbo's CPS correctly aligned at TDC with the cover off, good double-check item if you're not sure it's gone in right...
Old 08-19-2010, 06:00 AM   #5
Default timing belt tension
Everytime I messed with my timing belt, I pulled all slack out of the belt on the intake side, slipped the belt onto the gears (with them aligned properly), then let the tensioner take out all of the slack in the belt. Doing it this way allows all belt slack to be between the exhaust cam gear and crankshaft timing gear, meaning nothing will move while tensioning the belt.
Don't know if that's the right way to do things, but it's worked great for me and keeps it as a 1 man job
HTML code is On
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
Setting the timing?? Dejvid1785 MKIII Supra 0 02-16-2006 04:12 AM
Standard /static Timing setting WilliamBodie MKIII Supra 6 12-08-2005 11:35 AM
