Closed Thread
Old 02-06-2005, 12:12 PM   #1
jumper with a piece of wire t & e1 in diag box in the engine bay, jump in car, turn key to ign and count the codes from engine check light
example code
21
flash flash... flash
34
flash flash flash... flash flash flash flash
2 codes stored
14 & 52
flash...flash flash flash flash............. flash flash flash flash flash... flash flash
now go here and find out what your code means
http://www.cygnusx1.net/supra/library/TSRM.../fi/FI_026.html
Check this page for instructions also
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
(eddited by Green7mgte)
suprra_girl is offline
Old 10-15-2005, 07:02 PM   #2
corewitz
corewitz is on a distinguished road
will just like a paper clip work? I tryed that and the engine light is just on always and never blinks. Also there is a lot of white gunk in the diag. box, would that have anything to do with it?
corewitz is offline
Old 10-17-2005, 12:20 PM   #3
yep... ppl have used paper clips
that white gunk is used to keep the terminals in good health i believe
Old 01-13-2006, 03:17 AM   #4
lifesnotfair
Default Great!
Thanks, supra girl. I have no idea what "t" and "e1" mean, but I will try to search for this tomorrow.
My hood shocks are "tired", so I hate to look under my hood coz I need one arm to keep it up, or a stick, which I never keep around =P
lifesnotfair is offline
Old 01-13-2006, 09:55 AM   #5
hehe good luck with ya codes
look in engine bay
locate fusebox
beside fusebox = another box with diagnostic written on it
inside diag box on lid you will see pin diagram
find T & E1 (also known as TE1 & E1) on the lid then match up with diag pins and put wire or paper clip into those to connect them together and walah... your cel will flash or do something
Old 12-23-2006, 04:00 AM   #6
Monkey
Monkey is on a distinguished road
That white gunk is waterproofing/dielectric grease that helps keep water out of electrical connections, and it also helps to promote electrical conductivity.
Monkey is offline
Old 07-18-2006, 09:59 AM   #7
sounds like code 52 which is knock sensor, check to make sure your plugs aren't broken and that (if turbo) both are plugged in (if na) that "the" knock sensor is plugged in
get a piece of wire and you should have to open the lid on the diagnostic box, inside the lid is a diagram of what each pin is, there you should find where te1 and e1 is
if ever you do a diagnostic and you have put the wire in but your check engine light stays lit and doesn't blink thats because the wire has not made firm connection in both of the terminals
Old 09-09-2009, 09:13 PM   #8
red_armie_soviet
red_armie_soviet is on a distinguished road
I got 3 diff codes and they all seem to be electric, i got codes 24, 32, and 41, and im having a really hard time fixing them.
red_armie_soviet is offline
Old 01-07-2010, 12:32 AM   #9
Originally Posted by gfrererr13 View Post
Will this work the same for a MKIV Supra as well? or is there anything different that needs to be done? Thanks!
I would like to know what years this works for as well, I know it works for all MKIII, I don't know about the MKII or MKIV.
Anyone?
cre is offline
Old 01-07-2010, 12:44 AM   #10
Typically will be the same for all toyotas 86-95ish
Some MK2's apparently have some sort of diagnosis system but I'm not sure which ones exactly, it's apparently a 2pin plug with a cap on it that you short.
Closed Thread
HTML code is On
check engine light, no codes CallieFornia MKIII Supra 1 10-26-2009 01:40 AM
5m-ge check connectors tonster MKII Supra 2 04-08-2006 06:54 PM
Check engine codes BossHogg MKIII Supra 3 03-17-2006 12:14 AM
diagnostic codes Alberto O. MKIII Supra 5 07-29-2005 12:50 PM
