Old 02-08-2006, 06:51 AM   #1
TrDSpEeD717
TrDSpEeD717 is on a distinguished road
Unhappy Short shifter of a Mk3
Hey everyone i been looking for a short shift for my supra.I been asking around and everyone tells me all i can do is cut the shifter shorter but the gears will be the same.Does anyone kno where i can get one???
TrDSpEeD717 is offline   Reply With Quote
Old 02-08-2006, 09:36 PM   #2
ilovecars
ilovecars is on a distinguished road
im not sure if this is exactly what u are looking for but give this link a go
http://www.horsepowerfreaks.com/pric...part/Version_2
ilovecars is offline   Reply With Quote
Old 02-08-2006, 11:04 PM   #3
j3pz
here you go. you can make yourself a shorter shifter with the one already in the car and a aftermarket shift nob that uses screws
http://www.supras.com/06/techcenter/display.php?QID=30
Old 02-14-2006, 03:47 AM   #4
TrDSpEeD717
Thanks i found one there is a guy on ebay selling them.Easy install just search for it.he makes them all the time
Old 08-11-2010, 10:09 AM   #5
ianstaley
ianstaley's Avatar
ianstaley is on a distinguished road
Default Short shifter
Oh and I found this too whith pictues ian http://www.mkiiisupra.net/bbs/showthread.php?t=25670
Bored old git that loves his toyota's I have two one a Supra MK3 with a targa top the other is a brit Camry V6.
ianstaley is offline   Reply With Quote
Old 08-11-2010, 09:30 PM   #6
+1 ian.. nice find.
Old 08-12-2010, 04:39 AM   #7
It's known as the "SOGI mod". If you want short and don't mind sacrificing leverage, have at it. Generally it makes for a notchier shifting experience. If you've ever driven with a real short throw shifter you will not be impressed. I'm not fond of the stock shifter's height, but this mod isn't where it's at, IMO.
Old 04-17-2012, 01:46 AM   #8
Joefishizzle
Joefishizzle is on a distinguished road
im very interested in this mod....however i have some ???? if someone has done it or knows
1. on the 3 way to fit the gear knob, i like that he reused the original shifter and just cut it to make it shorter. however it just seams flimsy, i mean if you have to heat up the whole assembly and rip it apart with vise gribs, wouldnt you want to seal the two pieces back together with something? my thoughts would be that its gonna pull off one day driving. but idk. anyone?
2. If you choose to just use the lower part of the shifting assembly, i know ill need to tap it. however is the new base thick enough to tap it back to a stock shift knob thread pitch? he used a 10 x 1.50... i believe the stock is a 12 x 1.50?
If anyone has any more info that would be awesome. i just got my bushings today from driftmotion here in town and would love to do this. thanks
Joefishizzle is offline   Reply With Quote
Old 04-23-2012, 02:43 AM   #9
Some people have pulled the two pieces apart, cut both down and then reassembled with glue or RTV. Depending on how deep the shaft is still penetrating into the top portion this can still provide and extremely strong bond. If you've shortened it significantly I'd grind/melt/dissolve the original rubber, texture the inner rod and fill it like they did stock with a HIGH SHORE, two part urethane. I would use something with a little give though, not too rigid.
No, the inner rod is too thin do thread for a stock shifter. Either use a universal, thread for a different shifter, weld on a bolt end with the desired thread or reassemble like a stock assembly.
HTML code is On
Short shifter of a Mk3 TrDSpEeD717 MKIII Supra 5 08-11-2010 09:30 PM
short throw shifter Jeff_5_7 MKIII Supra 13 07-02-2009 02:23 PM
Short Shifter MOD is Done! 88Supraboy MKIII Supra 8 12-16-2005 04:03 AM
Short Shifter?! 88Supraboy MKIII Supra 4 12-01-2005 09:13 PM
I NEED A SHORT SHIFTER Black 5spd MKIII Supra 1 06-23-2005 07:11 AM
