Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 02-24-2012, 10:14 PM   #11
pandrade
pandrade is on a distinguished road
so basicly the lexus afm would be a good upgrade if combined whith lets say Rc injectors flowing at least 550?
pandrade is offline   Reply With Quote
Old 03-08-2012, 07:04 PM   #12
Changes in fuel need to be proportionate with changes in airflow. The Lex AFM only works with injectors flowing around 550 (unless you have other means of adjusting fueling). 660cc/min = too much; 440cc/min = too little; 200cc/min = way too little; 600cc/min = still too much. The 550's aren't quite perfect either, the mod relies on closed loop operation to trim low load fueling.... but it's close enough.
HTML code is On
Lexus AFM Questions Chromemoly MKIII Supra 0 07-05-2009 02:55 AM
Lexus or Toyota AFM. What is the diference? azerty MKIII Supra 4 04-30-2008 01:08 PM
Diferences between Lexus and Toyota AFM azerty Non-Generation Specific Questions 1 04-29-2008 07:56 PM
Lexus AFM question? rnoswal MKIII Supra 13 04-20-2006 06:34 AM
