Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 01-30-2006, 02:34 AM   #31
obrut89
obrut89 is on a distinguished road
get a lexus afm
I sell mk3 plastic model cars
contact me at serenacorbinsman@yahoo.com
obrut89 is offline   Reply With Quote
Old 02-01-2006, 02:09 AM   #32
mrnickleye
mrnickleye's Avatar
^^^ I would not bother with the lexus afm on a n/a engine. It won't really get you anything, as on a turbo motor. Also you'll need larger injectors to enjoy the lexus afm.
Old 02-01-2006, 02:19 AM   #33
obrut89
i didnt realize that we were talking about a na and no you do not have to have bigger injecters although it helps but i had the lafm on my car and boosted 16 lbs on stock turbo plus it helps stop fuel cut
Old 02-04-2006, 07:43 PM   #34
Isphius
Isphius's Avatar
Originally Posted by mrnickleye
^^^ This is true. But...7mge has 9.2 compression. You can run regular 87 octane under normal conditions, when the outside air temp is below 100*. The knock sensor will let the computer know if your getting any pinging, and it will back down the timing to stop the pinging, which is HP loss.
True, But i know wit my friends camaro, tpi and running 10:1 pistons, on regular gas you never hear a ping or knock or anything, it runs beautiful. its just because the knock sensors and computer are fast/good enough to prevent it. but like you said there is power loss...so it does help to run higher octane if your compression is higher than about 9:1. But my point is (to others) that just because you dont hear the pinging, doesnt mean its not retarding the timing.
Old 02-04-2006, 07:49 PM   #35
Isphius
Isphius's Avatar
Originally Posted by lifesnotfair
I don't have a big need for speed anymore.. just want it to have enough power to make donuts and powerslides and that sort of things. I'd rather not have a turbo on the daily driver, although my previous 2 turbo cars never gave me a problem... but non-turbo's are.... simpler? :P
"(MSD being that thing that makes the plug discharge more than once, right? I could also use some explination on this)"
God bless the forums. Too bad I'm probably the only dominican in here, heh. But I'll make ya guys proud of my Supra! =P
My n/a has plenty of power to get sideways, loop, spin wheels in 2nd gear, whatever you want really lol. MSD is a company, and i think what most people would be referring to is an aftermaket igniton coil, i guess. Also get a new cap and rotor, since the n/a has a distributor.
Old 02-06-2006, 06:56 AM   #36
Idaho
Idaho is on a distinguished road
Originally Posted by Bullz_EyE
I'd suggest looking into replacing the headgasket before anything else, and any maintenance issues should be taken care of before looking for more power.
Yes by us si the same..Many "users" buy Supra, drive it and immediatelly ask me for more power - how to upgrade, which turbochrger to change , inejctors etc..
everytime I answered, "at first you must take you Supra to good condition, and you will see more power.."
My expierience is, that most of buyed supras has blown head gasket, or bad piston rings and about 90% has crankshaft bearing and crankshaft damaged...
Idaho is offline   Reply With Quote
Old 02-16-2006, 11:28 AM   #37
Buying_90_Supra
Buying_90_Supra is on a distinguished road
Smile I am getting 89' or 90' Supra in 1 yr and a half
Yeah I am getting an 89' or 90' supra in 1 year and a half and is there any supras that are manual with targa tops or is it just all automatics...?
Because all of the supras that I have looked at are automatic with targas because I hell wanna get some because my brother drives a 1993 Nissan 300ZX Man Targa and it is hell good.
I am only 15 atm but am a car fanatic, when I get the supra I am gonna replace all parts first for instance head gasket with copper/metal gasket, belts and then chuck a stezza system in with a pioneer head unit and a couple of 4 way 6x9s and yeah just take it from there, maybe king springs and coils, lowered, K&N Air Pod and Exhaust tip.
Buying_90_Supra is offline   Reply With Quote
Old 02-16-2006, 06:52 PM   #38
j3pz
well to begin, the mk3 came in all combos: NA/turbo, manual/auto tranny, hardtop targa top. i have an 88 na mantranny, and a 87 turbo mantranny. as for the parts, looks like a good start with hg and belts. you also may want to look into replacing the vacuum hoses. you can buy a generic kit or whatever. i gotta system im tryin to sell if you're interested. pm me
Old 04-03-2006, 04:47 AM   #39
supratech
supratech is on a distinguished road
am i the only one having a hard time finding performance parts? e-bay has been good to me, but thats about it
mint 86.5 stainless header, knocked out cat, flowmaster exhaust, K&N filter, adjustable cam gears (6 degrees advanced) centerforce dual-friction clutch, 100hp dry nitrous shot, removed clutch fan, removed a/c, MAF/AFM, 17 lexus rims,
supratech is offline   Reply With Quote
Old 04-30-2006, 01:45 AM   #40
jaysun
jaysun's Avatar
jaysun is on a distinguished road
the headgasket and intake, a good ecu, maybe some new 50w oil and some stp. that will help you out a little. do some light weight deduction. replace some of your old piping and exuast and your car should be faster. i saw some intake parts (custom intake parts) at pepboys but its really low quality, i guess it does the same thing. its not metal its cheap plastic. thats a cheap way to get a custom intake
7m-ge
auto tranny
non turbo
so far stocked ..
jaysun is offline   Reply With Quote
HTML code is On
Best Bang For Your Buck 1988 Supra turbo jordanlovesmk3 MKIII Supra 3 07-26-2009 04:37 PM
