Old 12-04-2009, 08:53 PM   #111
TripleC
TripleC's Avatar
What about on 18 and 19 inch wheels
Old 01-04-2010, 09:10 AM   #112
In an effort to clean things up and make things easier to find I'm merging and cleaning some threads. Use this thread for posting questions about tire and wheel fitment or what you've found works for you.
Oh, and pics are always encouraged!
Old 01-05-2010, 02:13 AM   #113
Default Tire Sizes
just wondering what size of tire and rim comes "stock" with mark 3's?
what people here would recommend, and will 18 inch rims hold a 260/60??
Old 01-05-2010, 02:28 AM   #114
First sticky in the forum is for tire fitment. http://www.toyota-supra.info/forums/...t-q-and-a.html
I believe the stock "sawblades are 32 offset and the later model 5-spoke are 35.... I might have that backward, but the difference is minimal. stock rim size is 16" x 7".
What the 18" rim will fit depends on the width, not the diameter. I *think* you'd want around 8.5" or 9" wide, but it also depends on the desired profile.
There are more knowledgeable people here when it comes to tires, hopefully they'll chime in.
I'm merging this thread with the fitment sticky.
Old 01-05-2010, 04:11 AM   #115
92 mk3 7mgte.
225/50/16 -stock rims.
Old 02-04-2010, 02:01 PM   #116
Hitman2021MkIII
Hitman2021MkIII is on a distinguished road
Default will this fit
285/35r19 on Rear 245/40r18 on Front
i won them off a corvette
Hitman2021MkIII is offline   Reply With Quote
Old 02-07-2010, 12:38 AM   #117
mk3teen
mk3teen's Avatar
mk3teen is on a distinguished road
anybody have rims that were oem from 91 and up for sale? lokin for sum
mk3teen is offline   Reply With Quote
Old 04-19-2010, 03:20 AM   #118
StonecoreTx
StonecoreTx is on a distinguished road
I'm looking for a mesh type wheel to put on my mk3. i'm really wanting the 1980 style mesh rims for firebird/trans am really bad. enkei 92's are only 4 lug =( anyone have any simular ideas, i herd they made one with a diff lug pattern for the fiero? will these fit?
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
Old 04-19-2010, 10:04 PM   #119
StonecoreTx
fitment question: will GTA wheels off of a trans am fit? I'm not sure on the specs and found some for dirt cheap, if not I plan to go with the crown vic meshes but prefer the GTA's to fit *crosses fingers* anyone know? because I plan on picking them up this weekend
Old 04-22-2010, 12:02 AM   #120
StonecoreTx
fitment question. I've decited to go for a oem/mesh look. i'm thinking some GTA mesh wheels off of a 80's trans am. would it be possible? similar to crown vic meshes. I really want this wheel any tips will be appreciated asap because I found a set for dirt cheap and would make my day if they fit.
http://www.tacreationsusa.com/firebi....htm#GTAWheels - this site has alot of into about the GTA wheel.
GTA wheel specs:
Size : 16" x 8"
Backspacing Front : 4.75"
Backspacing Rear : 5.25"
Bolt pattern : 4.75"
Material : Aluminum
Finish : Painted Centers/Cleared Lips
WILL THESE FIT?
HTML code is On
water build up in spare tire wheel, 87 supra---any solutions?????? ogkush MKIII Supra 5 09-17-2011 09:42 PM
wheel fitment - who wants enkei? carl johansson MKIII Supra 7 03-25-2010 12:56 AM
replacing wheel stud Rahnter MKIV Supra 3 12-10-2008 03:57 PM
edgeracing.com - wheel & tire packages Nato99 Non-Generation Specific Questions 5 06-22-2007 04:33 AM
