Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 01-27-2006, 01:13 AM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Blown Head Gasket Symptoms!
I have a 88 NA supra, i'm trying to figure out if my thermostat is out or is my head gasket blown? What usually happens or what symptoms there are when your head gasket is blown?
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 01-27-2006, 01:30 AM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Originally Posted by Dejvid1785
...or is my head gasket blown? What usually happens or what symptoms there are when your head gasket is blown?
Read the second half of this post:
http://www.toyota-supra.info/forums/...00&postcount=6
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Old 01-27-2006, 04:54 AM   #3
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Milky oil cap.
Milky dipstick.
Coolant loss.
Steam out of exhaust.
That's the stuff I saw yesterday after I drove my car for the 1st time in over a month, after replacing the head gasket. Yessssss.
Oh, and when you drain the oil, it should be nice and watered down too.
Function Over Form - Form Follows Function
88 MkIII Jurbo
Bullz_EyE is offline   Reply With Quote
Old 01-27-2006, 11:42 AM   #4
TONY!
TONY!'s Avatar
Milky oil cap.
Milky dipstick.
Coolant loss.
I guess you had a water jacket to oil channel leak.
Not all BHG's are like this, I think most are the cylinder to water jacket leak type.
With my BHG, the oil was perfect. It came to a point where the combustion gasses would just cause the car to spit out coolant even in idle, yet the oil and coolant never mixed or had a leak amongst each other.
Old 01-27-2006, 02:36 PM   #5
Bullz_EyE
Bullz_EyE's Avatar
My cars tail pipe looks like it's a steam engine. lol, I'm replacing my MHG with a composite one tomorrow.
88 MkIII Jurbo
Old 01-28-2006, 02:01 AM   #6
Dejvid1785
I don't have any smoke out of the exhaust or milky oil, but i am losing coolant!! Could that still be thermostat or something else? My temp gauge never stays still it sits up top showing that its over heating but the car isn't over heating and is driveable and suddenly it jumps back down, if anybody knows answer me. Thanx!
Old 04-24-2011, 07:59 PM   #7
D.Bess
D.Bess is on a distinguished road
u know anyone who can help me replace my headgasket and put everything back together im not familar with the wire harness and where everything goes????
D.Bess is offline   Reply With Quote
Old 12-26-2006, 08:33 AM   #8
mookydaspooky
mookydaspooky is on a distinguished road
Try to take out the old thermostat and punch out the insides of it and then replace it. Then you will know that it is not your thermostat.
Does your car use up any water? If so, and it probably does, then it could be your head gasket. I blew two head gaskets, on two different engines in the past year. You need to check your distributor!!! That is what caused both of my engines to blow. There are three different modules in the inside of the distributor that you need to check. You can test them in a few minutes, with a meter. I used my old distributor in the new engine I bought, which was a big mistake. I do not want you to make the same one. My car was smoking and burning oil. Also, when I checked the timing on my car, it was fine. But, when I advanced the engine, the timing went off the chart. This was do to two of the modules in the distributor going bad. A new distributor is only $256.00, from Toyota. Let me know if this helped you. David
mookydaspooky is offline   Reply With Quote
Old 01-23-2007, 02:52 AM   #9
Jermalicious
Jermalicious is on a distinguished road
Exclamation Blown Head Gasket
My 87 Supra has a blown head gasket and ive heard about certain head gaskets that help with the tourque spec issue Toyota had back in the day. I would like to know what people would recomend for me to get for a head gasket.
Jermalicious is offline   Reply With Quote
Old 03-07-2007, 03:04 PM   #10
mkIIIdraper
mkIIIdraper's Avatar
mkIIIdraper is on a distinguished road
Exclamation
just finished putting back together after head gasket replacement now my car doesn't start
help !!!!!!!!!!!!!!!!!!!
could it be timing or is one of the vacuum hoses incorrect or what
ps i'm not that proud to say but i didn't mark the vacuum lines when i took them apart
88 mkIII, manual, turbo, hks valve management system, non restrictive exhaust, cold air intake, 15lbs, 12.89 @108 mph
mkIIIdraper is offline   Reply With Quote
HTML code is On
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown head gasket? h8z2luze MKIII Supra 30 06-03-2006 03:18 AM
