Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Closed Thread
Old 12-29-2004, 12:20 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the mk3 supra has 6 different engines in total (all straight 6's)
1geu
SOHC
2L non turbo
(have seen only once here in new zealand, and yes even the vin tag showed a factory engine of a 1geu)
power = 120hp @ 5400rpm, torque = 127ft lbs @ 4400rpm?
1ggeu
DOHC
2L non turbo
power = 140hp @ 6400rpm, torque = 127ft lbs @ 4400rpm
1ggte
DOHC
2L twin turbo
turbos = ct12 x 2
water intercooler (my term... soapbox hehe)........... (1986-88?) power = 185hp @ 6200rpm, torque = 173 ft lbs @ 3200rpm @ 6psi
air to air intercooler (1989 +) power = 210hp @ 6200rpm, torque = 203ft lbs @ 3800rpm
7mge
DOHC
3.0 non turbo
power = 200hp @ 6000rpm, torque = 185ft lbs @ 4800rpm
7mgte 1986-1989 (mid year changeover)
DOHC
3.0L Turbo
turbo = ct26 x 1
power = 230hp @ 5600rpm, torque = 240ft lbs @ 4000rpm @ 5psi
1989-1992 7mgte
power = 232hp @ 5600rpm, torque = 254ft lbs @ 3200rpm @ 5psi
1jzgte
DOHC
2.5 Twin Turbo
turbos = ct12a x 2
power = 280hp @ 6200rpm, torque = 269ft lbs @ 4800rpm
Pics of my build.
Do a diagnostic first!
suprra_girl is offline
Closed Thread
HTML code is On
Supra JDM specs Lunch2000 MKIII Supra 0 10-24-2006 01:26 AM
