The first thing you need to make sure is that your car is in good running order before you do any modifying
especially check the hg ;) if you haven't done your head gasket i would definitely suggest doing this first *get a metal head gasket and a set of arp head studs at least you're not gonna blow it ;) if you have a good head gasket or already have done the mhg then we can start with some mods :D
now if you've gotten this far... congratulations to you does anyone else have something to add here i may have forgotten? good luck to your supra and with your mods ;) |
uh, i think you forgot about the 5spd guys. more power and boost needs a clutch. by next week i'll have a centerforce dual friction in mine, only because i got a really good price on it. i dont remember you posting on the ignition system, suspension or brakes either.
Tires, shocks, springs, and sway bars and if you believe in them, strut tower braces. I also remember seeing a brace that goes on the inside of the car in front of the back seats.
Those are in order pretty much, tires will make a HUGE difference on how it handles and accelerates. All the other things are meant to kepp the tires on the ground and planted, but the tires are still the main part of the equation, don't skimp on em. Also, you can go with bigger breaks from Wilwood, but factory breaks are really nice as it is. If I recall correctly the Mk3 Supras pulled just under .9g's on the skidpad off the showroom floor...better tires will help a lot compared to tires from then, so it's not like Supras are slouches on the twisties... |
