Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 03-07-2007, 12:56 AM   #111
IHateHacks
IHateHacks's Avatar
Oil on top of the spark plugs has nothing to do with the electrode side (the part of the plug that is in the combustion chamber) or the head gasket.
"was it the pix were ur head gasket lookd like oil was sitting there for along time"
I have no idea what you are refering to.
"and if i just get a stock size HG will it still blow on me if its not a MHG"
It's not the gasket that fails it's the head bolts. They were undertorqued at the factory, causing them to strech. As long as you properly torque the head bolts it doesn't matter what gasket you use.
Old 03-07-2007, 04:41 AM   #112
88Tsupra
88Tsupra is on a distinguished road
thank you. im going to make sure its torque correctly after i go get me a torque wrench...sry buh how much ft/lbs should i re-torque it too
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 03-07-2007, 03:41 PM   #113
IHateHacks
IHateHacks's Avatar
That is a matter of opinion. ARP recommends 86 ft/lbs for their 12mm STUDS. ARP does NOT list a torque value for their 12mm BOLTS. And yes, torque values for studs and bolts are different. Factory specs are 58 ft/lbs which is too low, but I've heard (I can't confirm, maybe someone here has a link) that toyota reissued a new torque value for head bolts which is 72 ft/lbs. I personally torqued my ARP bolts to 70 ft/lbs. I'd say anywhere between 70 and 85 ft/lbs would be fine.
Old 03-07-2007, 08:32 PM   #114
88Tsupra
ty i appreciate the help alot..now i just gotta ask my uncle to torque down the bolts cuz i dont know where they're at..thanx man u saved me a bhg
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 03-08-2007, 01:30 AM   #115
JMoses
JMoses is on a distinguished road
The Haynes Manual calls for 85 ft lbs
JMoses is offline   Reply With Quote
Old 03-08-2007, 06:10 PM   #116
IHateHacks
IHateHacks's Avatar
You better check your lupe.
Haynes manual calls for 58 ft/lbs. Do I need to post a picture?
I follow the TSRM anyway, not Haynes.
You might be dyslexic. 85--->58??
Old 03-08-2007, 07:26 PM   #117
IHateHacks
IHateHacks's Avatar
88Tsupra- The head bolts are underneath the cam covers. If they are factory head bolts, you will need a 10mm allen head socket. It will have to be 3/8" drive to clear the cams and lifter bores. If they are ARP bolts, you will need a 1/2"(size, not drive) 12 point socket. Again, it will need to be 3/8" drive to clear the lifter bores. Then use a 3/8" extension and a 3/8" to 1/2" drive adaptor to use a 1/2" torque wrench.
And as a side note, the cams will need to be set at TDC in order to fit any kind of socket down past them to the head bolts. This is because of the castings of the cams have special ridges casted into them that have flat spots right in the spot where the head bolts are. You will see what I mean if you ever torque the head bolts yourself. In my opinion I think Toyota did that as a fool proof way of making you set the engine to TDC before you take the head off.
Old 03-09-2007, 01:14 AM   #118
88Tsupra
thanx hate i appriciate this alot man..this is my first car and its become a gold digger...now if i can just get it torque right maybe then i can stop worrying about it..besides worrying why so much oil is draining out my car so damn fast and ending up on the side of the cam covers and side of the oil cap..depressing but entertaining..also is it ok if my exhaust tip has water all around it when i warm up the car
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 03-09-2007, 02:16 AM   #119
IHateHacks
IHateHacks's Avatar
As far as your oil leak around the cam covers you might wanna take a look at the sticky "Got oil on top of your spark plugs?". If that does not apply to you, then you just need new cam cover seals. Not a dealer only part. You can buy them at any parts store for around $30.
As far as the water around your exhaust tip, if you still have the cat on it, thats perfectly normal. You see, a catalytic converter oxidizes, reduces and converts exhaust gases which are HC (hydrocarbons), CO (carbon monoxide) and NOx (oxide of nitrogen) into CO2 (carbon dioxide), N2 (nitrogen) and H2O which is water (duh).
Edit: oops I just saw that you posted in that thread. My advise to you is to replace all the hoses that attach to the cam covers. That would be the 2 PCV hoses (the 2" ones right in the middle of the covers) and the big hose that is to the right of the oil cap. I can guarantee you if you take that big hose off when you take the covers off, it will crack. It's a dealer only part and its $25.95.
Old 03-09-2007, 06:30 AM   #120
88Tsupra
thanx man your a big as help..as for the leak i plan on buying a gasket seal next wednesday then gettin new hoses to...oh i read the Sticky about the oil and if its that i guess ill just have to replace it like u said..thanx a million
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
HTML code is On
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Head gasket repair Kuban MKIII Supra 9 07-20-2007 09:01 PM
