Old 10-23-2007, 04:20 PM   #1
Jrew
Jrew's Avatar
Jrew is on a distinguished road
Default Car Died...where to start?
Ok went to start my car this morning and nothing... it cranks but won't start. I tested the battery...its fine. Now, i have yet to replace the spark plugs since i bought the car nearly a month ago and i have had some weird start ups in the past on a cold start. Typically the car would crank for a bit then finally start up but i seemed to need more time than usual to fire up. Anyhow, now it won't turn over at all. I was going to just replace the plugs to see if that fixes it, and if it doesn't then i have new plugs i suppose. If that doesn't work however, where should i go next? Thanks for the help
Jrew
If you're going to strive, strive to be the best.
Jrew is offline   Reply With Quote
Old 10-23-2007, 04:36 PM   #2
Supra2NR
Supra2NR's Avatar
Jrew
cold start injector?
Old 10-23-2007, 06:56 PM   #3
IHateHacks
IHateHacks's Avatar
I would test fuel pressure at the fuel rail by removing the 17mm banjo bolt in the top of the fuel rail that is facing the hood and installing a fuel pressure gauge. Then I'd test the coils and igniter or coil if its a GE.
Old 10-26-2007, 03:15 AM   #4
plaaya69
plaaya69's Avatar
If its a 7m GTE, Then check the wiring by the CPS and the small wiring harness that comes off of the coil pack onto the main engine wiring harness. Maybe wiggle it a little. I had that problem and I had to replace some wires because of all of the heat from the exhaust manifold.
Old 10-26-2007, 02:19 PM   #5
http://www.toyota-supra.info/forums/...ead.php?t=4657
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
