Old 11-02-2007, 01:43 AM   #1
Chambers
Chambers's Avatar
Question A Few Q's on Turbo Injectors
Hi all, the first question; Does anyone know what kind of electrical resistance is running on the turbo fuel injectors if any? Because in the TSRM it has says to test the turbo injectors with a resistor on from the power source. Second; Has anyone put stock turbo injectors in a NA? Thanks.
"Stuck in the 80's"
Old 11-02-2007, 02:31 AM   #2
supraman121
What do you plan on gaining from putting turbo injectors on an na supra? Im just curious.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 11-02-2007, 02:33 AM   #3
Chambers
Chambers's Avatar
Well I'm doing a NA-T and wondering about the resistance on the turbo injectors, becasue if they have a resistance on the turbo car, they would rock on the NA with no resistance.
"Stuck in the 80's"
Old 11-02-2007, 03:27 AM   #4
supraman121
O well i cant really help you lol i was just wondering, is it all that hard to do the na-t conversion?
K&N Air Filter
Old 11-02-2007, 03:53 AM   #5
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
you shouldn't have to worry about the resistor pack if you are going to put the turbo injectors on the n/a. the n/a's also have resistor packs wired into the hareness so its just plug and play, a direct drop in
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 11-02-2007, 03:16 PM   #6
Chambers
Chambers's Avatar
Thats ok, I wouldn't call it a NA-T conversion, I'm still using all the NA parts, I'm just swapping out the bare minimum, such as injectors and possibly other fuel delivery systems, and just adding the turbo. But yea it can be pretty hard.
Sweet, that helps, but I have another question, is that resistor pack in the harness or is it in the ECU? I've been looking over the TSRM and haven't found any information on the resistance running to the injectors, so I haven't found where it its yet. Thanks.
"Stuck in the 80's"
Old 11-05-2007, 06:24 AM   #7
86_sports_1jz
its on the chasis by the driver strut tower, the fuel pump resistor pack is on the passanger strut tower
Old 11-05-2007, 12:53 PM   #8
Chambers
Chambers's Avatar
Question
Is the location the same on both turbo and non-turbo cars? Thanks.
"Stuck in the 80's"
Old 11-05-2007, 05:33 PM   #9
86_sports_1jz
yep, they are located in the same spots. turbo or nonturbo
Old 11-06-2007, 03:26 AM   #10
Chambers
Chambers's Avatar
Thumbs up
Ok, that works, thanks!
"Stuck in the 80's"
