Old 11-02-2007, 02:47 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
Default need help quick please
well i cleaned my MAF sensor with the appropriate cleaner and after i reasemmbled everything i started my car and the instant i touch my gas now the car stutters and dies instantly same thing everytime
cyanide-is-a-way-out is offline   Reply With Quote
Old 11-02-2007, 03:05 AM   #2
Question
Why did you cleen the MAF?
What was the car doing before you did this?
Old 11-02-2007, 04:08 AM   #3
i cleaned it because it was recommended to so i used the stuff to clean it and now when i touch the gas it shutters and dies
Old 11-02-2007, 04:55 AM   #4
redmaro
What did you use to clean it with?
MK3, Auto, Turbo.
Old 11-02-2007, 04:27 PM   #5
well it was some stuff said to clean the sensor in seconds blash blah blah and the thing i cleaned was the sensor right behind the air filter
Old 11-02-2007, 07:16 PM   #6
redmaro
Maybe you should let it sit till it dry completly.
Or the MAF is probably messed up now.
MK3, Auto, Turbo.
Old 11-02-2007, 07:56 PM   #7
i think it is messed up now its sat since last night and it still stutters when i touch the gas
Old 11-03-2007, 12:17 AM   #8
west_side_supra
west_side_supra's Avatar
make sure its connected, mine i was trying to figure out what was going on with my car and had the same symtom, then i remembered that my MAF was the last thing i worked on. forgot to plug the harness in.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-03-2007, 01:01 AM   #9
i made sure it was plugged in i tried to drive it today and it drove fine then all of the sudden it lost power and started shaking violently and jerking
Old 11-03-2007, 02:58 AM   #10
CyFi6
sounds like theres a problem in the connection
You didnt unscrew the two phillips screws by the connector did you?
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
new to forums... some quick Q's gfx MKIII Supra 3 10-12-2005 01:54 PM
