#1 |
hi can anyone tell me what i need exactly inorder to run a 7mge with turbo without problems, ok i already have a stock ct-26 turbo, exhaust manifold, downpipe, intercooler and piping plus 550cc injectors but from other forums it seems that i am missing alot more parts sow can anybody help??
#2 |
Technically you should be able to bolt that on and it should work... but the ecu in the car isnt tuned for it so i dont no what you would do about that, your going to need to find some way to get oil to the turbo and water, iv heard of poeple leaving the water hole unhooked to compensate for no water, iv been told you need a cam positioning sensor but no one will tell me why, and if your going to try to bolt this on i would recommend a boost gauge and maybe a controller, you could always ask a local shop what is need to boost it a tuner shop should know... dont just bolt it on because i said it would work i would ask some shops around what is required.
Upgrades- 225/50/R16's Kumho ECSTA AST (KU25) 273 bucks with shipping Magnaflow exhaust NO KAT K&N Air Filter www.myspace.com/coreyjstevens http://vids.myspace.com/index.cfm?fu...oid=1536317037 <------ this one should work check out the accident one aswell ya i might be a "fat kid" but i sure can move fast!~ |
#3 |
yeah but is other forums ive red that ppl upgrade theyre fuel pump, they get a new oil cooler, replace oil pan with 7mgte oil pan, replace upper intake with throttlebody with a 7mgte upper intake with throttlebody nd lots more stuff and also better not to go over 8psi
#4 | |
![]() Quote:
#5 |
okay so what doyou recommend for me to do
#6 |
You dont need a CPS or a coil pack if you dont plan to use a 7M-GTE computer, and if you do then why not pony up $1,000 bucks for a complete JDM 7M-GTE with the computer, because the NA has a diffrent ignition system. I'm almost ready to finish my NA-T project, all I need is a BOV and to mount my intercooler. I was lucky enough to get a JDM engine in my car and the NA block had the oil retern for a turbo, it was located below the oil filter, so all I had to do is tap into the oil pressure sending unit. As for the water line there is a small line on the termastat houseing that goes from the top to the bottom outside of the housing, thats where I'm tapping the water from.
I've beent trying to get all the info I can about the injectors and the resistance running to them, becasue the way I see it, it might be possible to "fool" the NA ECU into sending more volts thru the injectors by modifying the resistance to the injectors. This way I can make a NA-T keeping the NA ECU. Hope this helped, good luck. |
#7 |
Did I read that right
"They put the oil cooler was installed to get oil to the turbo" You gotta be kidding me And a the 7mgte oil pan has the return? Since when Ok the oil cooler is pretty self explainatory, it cools the oil Kinda like how the radiator cools the water, And an intercooler cools the air, so you get my point You need to find a oil feed for the turbo, since I would assume the same location is not tapped on the na block And the 7mgte oil pan does not have a tap for the return Maybe bigger for more oil capacity The return line is tapped into the block, which isn't on the na block, With the coilpack you also need to get an igniter, since they're a completely diffrent ignition system from the na And there's a reason why the turbo is watercooled, what that reason is, idk and don't care ,I got a diffrent setup now, but they designed it that way, and I can only assume it will work more efficiently and properly if you keep it that way Get a thermostat housing from the deal that's for a 7mgte If I miss sumthing, or mispelled, my fault Im at work right now
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#8 |
thats why i sed thats what others posted on other forums
#9 |
Unless you get a coil pack, igniter, CPS the 7M-GTE therm housing wont work, the distributer is in the way of the water lines to the turbo.
As for the oil return, on my NA block there is a plate blocking off the return hole for a turbo, but no tapped hole for the oil feed. |
Thread Tools | |
Display Modes | |
7MGTE to 7MGE | karu | MKIII Supra | 4 | 10-22-2010 07:22 AM |
Turboing A 7mge | SilenceboneSupra | MKIII Supra | 3 | 10-20-2007 10:53 PM |
1JZ-GTE Engine with 7mge Stock Fuel Pump | joolhamdi | MKIII Supra | 1 | 06-10-2006 10:29 AM |
7mgte AFM on a 7mge | boogum7 | MKIII Supra | 1 | 04-07-2006 02:12 AM |
7mge vs. 7mgte | KNYFE | MKIII Supra | 3 | 09-27-2005 02:21 PM |
