Old 11-13-2007, 04:40 PM   #11
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
Originally Posted by 86SupraMan
hmm.. ok maybe tranny will need to wait till i get more cash lol, 1 more question ive bin wondering about, ive bin lookin at aftermarket throttlebodys, but theyre all for the GTE, would they fit in the GE? or would i need one specifically designed for the GE?
The TPS is mounted on the throttle valve body and sends a varying voltage signal to the ECU based on throttle valve position. The ECU can then adjust fuel delivery based on acceleration, deceleration, full throttle (WOT) or idle. The TPS inputs the ECU through terminal VTA.
the throtle body off a 7mge wont work on a 7mgte im shure it will bolt up but the routing is totally different as in the picture so your best bet is find one for a 7mge
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
tsupra89 is offline   Reply With Quote
Old 11-13-2007, 04:41 PM   #12
tsupra89
tsupra89's Avatar
and here is what your resistance should be so the tps will fit for both
lexus afm
k&n air system
walboro fuel pump
apc hood pins
yellow fogs
Soon To be
Old 11-13-2007, 06:09 PM   #13
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
Originally Posted by tsupra89
actually i found out today, the automatic is the same in both models a340e but in the manual versions the non turbod supra is a w58 and it is weak, the one in the turbo is a r156 and it has very different internals so the autos are the same but the manuals arnt
the autos on the gte might be a little stronger but i cant confirm that, the w58 is not by any means weak, it can hold up to 400hp, toyota doesnt make weak trannies, and its r154, not r156, that can hold loads of hp, front half of the driveshafts are all different on all models
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 11-13-2007, 06:12 PM   #14
tsupra89
tsupra89's Avatar
yes i agree the trannys are both built powerful but i would much rathyer have the r154 because of the internals they built the r154 for the turbo and it it stronger then the w58 so i would rather go with the r154
lexus afm
k&n air system
walboro fuel pump
apc hood pins
yellow fogs
Soon To be
Old 11-14-2007, 02:41 AM   #15
oowee623
oowee623's Avatar
i agree but no need to call the w58 weak
Old 11-15-2007, 01:26 AM   #16
j3pz
unless you plan on going turbo i wouldnt worry about getting a r154. a w58 will be cheaper and is just as much fun to drive
Old 11-16-2007, 03:46 AM   #17
tsupra89
tsupra89's Avatar
i have a turbo im wanting to swap to manual. and i was wanting to know if they were the same but i did the reasearch and im showing everyone the differences in the trannies
lexus afm
k&n air system
walboro fuel pump
apc hood pins
yellow fogs
Soon To be
Old 11-16-2007, 07:04 AM   #18
oowee623
oowee623's Avatar
might wanna get lsd if you dont have one
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
