Old 11-07-2007, 02:40 AM   #1
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
Default i have a question in dire need of answering
alright i need some advice, ive heard that hks head gasket and arp head bolts are the best combo. but i have a bigger dilema mines automatic. i need to know if the stock 7mge transmission will fit into a 7mgte. i know the trannys are the same a340e but i dont know if they have different ratios or different internals. i need to know caus ei found a running supra for 400 bucks but i dont know if the n/a tranny will do the job for my turbo engine??? please get to me
tsupra89 is offline   Reply With Quote
Old 11-07-2007, 05:48 PM   #2
abhattan
abhattan's Avatar
I would think not. The NA manual tranny doesn't work for the turbo cars, so I don't think the NA automatic would work for the turbo car. Not strong enough. Or different lengths.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Old 11-08-2007, 02:28 AM   #3
tsupra89
tsupra89's Avatar
actually i found out today, the automatic is the same in both models a340e but in the manual versions the non turbod supra is a w58 and it is weak, the one in the turbo is a r156 and it has very different internals so the autos are the same but the manuals arnt
Old 11-08-2007, 02:29 AM   #4
tsupra89
tsupra89's Avatar
bu tthank you for your feedback.
Old 11-08-2007, 05:31 AM   #5
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
the manual trannies are different but you can still use a non-turbo tranny w/ a turbo motor and viseversa. the only thing about that is that the w58 doesn't hold power like the r154
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 11-08-2007, 03:50 PM   #6
tsupra89
tsupra89's Avatar
qyeah weaker internals so i would rather find a turbo tranny. but if anyone needs a good running supra for a g i know where one is, its been wrecked maybe like 3g damage but it runs and you can prolly get it for like 800 if you want to drive to asheville
Old 11-09-2007, 03:44 PM   #7
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
ok, so im sittin here now, wondering whether a Turbo tranny will swap into a non turbo car with no hiccups... anyone care to enlighten me?
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 11-09-2007, 06:10 PM   #8
supradaddy0803
supradaddy0803's Avatar
Should be able to swap a turbo tranny into a N/A. If you get the R154 with the bellhousing for the 7MGTE they have the same housing. The only problem you will have is the driveshafts are different. But that is easily fixed if you get a solid driveshaft. I would say yeah go ahead and swap it but if you just wanna W58 I have one you can have just come get it. As for the different lengths on the W58 and the R154 they are the same length I measured because I wanted to know before I put my 1JZ in.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 11-12-2007, 04:50 PM   #9
tsupra89
tsupra89's Avatar
hey guys i have the answer to your solution the break down of the transmissions themselves.
and here is the info on the tranny's the gear ratios as well
Old 11-13-2007, 04:00 PM   #10
86SupraMan
86SupraMan's Avatar
hmm.. ok maybe tranny will need to wait till i get more cash lol, 1 more question ive bin wondering about, ive bin lookin at aftermarket throttlebodys, but theyre all for the GTE, would they fit in the GE? or would i need one specifically designed for the GE?
86.5 Toyota Supra
((Current Mods)) :
-K&N Filtercharger
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
