Old 11-09-2007, 03:02 AM   #1
Chambers
Chambers's Avatar
Question Having ECU Power Issue
Hi all, I've been having occasional issues with starting my car. This morning I went to start my car and nothing, the engine wouldn't even turnover. Originally I thought it had something to do with the ECU main, in the fuse panel under the hood. But after swapping through 7 ECU mains the car still didn't stat, so I had to get a ride to my back up vehicle, not a big problem. I was thinking I would go to the dealership and get another main for temporary but then I thought it might be a ground, so I check the ground from the battery to the body and engine, and they were good, I don't know where any other grounds are so I haven't check them all.
When I got home about one hour ago I went out looked at the main, and the grounds again, then tried to start it, it turned over instantly but it took about four turnovers for it to start and it was running rough, so I popped the gas pedal and it started to idol fine. I then got hit with a big cloud of exhaust that smelled like unburnt fuel, it lasted for about one minute. So now I know the ECU is getting power because it pumped fuel into the cylinders and didn't burn it until I started it later. I'm not looking for the quick fix or the answer to all my problems, just suggestions and accounts if anyone else has had this happen to them. Where should I start to check the systems, and how should I go about the checks? Thanks.
"Stuck in the 80's"
Old 11-09-2007, 03:19 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
I used to have a 92 Jetta Gl, and one of my biggest problems was that when I turned the key, sometimes the starter wouldn't turn. Everything else happened correctly (i.e. radio turn off when holding to start, lights turn off, etc.) when I would turn it. My problem came from two angles. I had a bad chassis ground from the negative terminal on the battery, and the wires for the ignition were pulled so tight that they were starting to come out, causing a bad connection. I'm sorry if this isn't what your problem was, it's how I interpreted your post.
Old 11-09-2007, 04:21 AM   #3
mrnickleye
mrnickleye's Avatar
http://www.cygnusx1.net/Supra/Librar....aspx?S=ST&P=1
Old 11-09-2007, 03:53 PM   #4
Chambers
Chambers's Avatar
Thanks to both of you, I will check all three things, and replace what I must and go from there. Thanks again.
"Stuck in the 80's"
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
only starts by jump start ItsnotmySupra MKII Supra 6 04-27-2008 03:14 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
