Old 11-10-2007, 02:42 AM   #1
tokis
tokis is on a distinguished road
Default mk3 wont pass 40 mph??
i just bought a 1987 mk3 auto turbo. Car take off fine until it hits around 40mph, start bogging and struggling. My buddy says its a ECU problem, too much fuel maybe? cuz its blows out black smoke when I take off. plz help me I'm new to supras
tokis is offline   Reply With Quote
Old 11-10-2007, 03:32 AM   #2
Supra2NR
Supra2NR's Avatar
could be the regulator since you said it was blowing black smoke
have you checked the sparkplugs? coilpack
maybe sum of them are fouled and youre not burning the fuel anymore
jus a few thoughts
Old 11-10-2007, 04:11 AM   #3
tokis
my car just had a full tune up
Old 11-10-2007, 07:13 AM   #4
redmaro
Any check engine codes?
BTW the ECU should be one of the last things you check IMO.
MK3, Auto, Turbo.
Old 11-10-2007, 08:20 AM   #5
tokis
yea got it checked. its not the right code
Old 11-11-2007, 12:10 AM   #6
Too rich running will cause the cat converter to fail. Perhaps you have a plugged exhaust, which will do what your car does.
Old 11-11-2007, 04:54 AM   #7
supramacist
supramacist's Avatar
I don't think your ride would roll if you had an ecu problem.
My car will start and idle but it sounds like a loping v8.
The timing is dead on balls acurate 100% no doubt.
I replaced the afm. Then replaced it again.
My ecu has to be fragged.
Upon test driving I blew a coolant line ond it fogged the cab through the
air vents and it's been absolute filth sinse that day.
Does anyone know anyone trust worthy to send this thing to for service.
Or even better does any one have a 90/91/92 manual tranny ecu they know works and wants to sell??
Old 11-11-2007, 05:57 PM   #8
redmaro
Supramacist is it N/A or Turbo?
MK3, Auto, Turbo.
Old 11-11-2007, 09:06 PM   #9
supramacist
Non turbo.
Wich is the problem. Ecu's for turbo's are everywhere.
Old 09-30-2009, 02:43 AM   #10
dupra87
dupra87 is on a distinguished road
Default 4o problem
i would say its your cat. i would start there. just unbolt it drive around the block if it goes passed 40 then thats it,, easy fix straight pipe done problem. anyways my opoin. good luck
dupra87 is offline   Reply With Quote
Please Help Me Pass Emissions scruffboy Non-Generation Specific Questions 20 09-05-2009 08:44 PM
code 52 knock sensor can't pass emissions hotrod705 Non-Generation Specific Questions 12 08-18-2009 07:44 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
How Can Jdm Engines Pass Emmisions Supra2NR MKIII Supra 1 08-25-2006 11:28 AM
