Old 11-15-2007, 04:22 AM   #1
Izapyou
Izapyou is on a distinguished road
Default Boost max
I bought a 88 turbo 5spd with custom parts and jdm motor for $800, need info on max boost on stock motor and ecu without reaching serious fuel cut.
Izapyou is offline   Reply With Quote
Old 11-15-2007, 03:04 PM   #2
redmaro
Max boost on the stock Turbo is 14psi, im not sure what max boost on the engine is.
And fuel cut is around 11-12psi stock. Fuel Cut is reached at different levels depending on the car.
MK3, Auto, Turbo.
Old 11-16-2007, 08:33 PM   #3
Izapyou
Ive got a gt26 dual ball bearing turbo, so fuel cut is @ 12 psi. Can you feel fuel cut, and is there a cheap fix to eliminate that problem.
Old 11-17-2007, 12:08 AM   #4
redmaro
Youll need a Lexus AFM and some 550's injectors, I believe the lexus afm and the 550's will raise you fuel cut to 18psi. Search on Ebay for the Lex afm.
Or you could buy a fuel cut defender VVVVlink
http://www.suprastore.com/hksfuelcutde.html
MK3, Auto, Turbo.
Old 11-20-2007, 09:04 PM   #5
Izapyou
What is the stock turbo number mine says Toyota GT26 turbo is this stock
Old 11-21-2007, 03:23 AM   #6
Chambers
Chambers's Avatar
It may be a different size turbo, the stock turbo on the Supra was the CT-26.
"Stuck in the 80's"
Old 12-06-2007, 02:28 PM   #7
Spudboy
Spudboy's Avatar
HKS Fuel Cut Defencer
I have a '88 Turbo, upgraded turbo (37 trim) and fuel cut defencer but need 550 injectors. What exactly are these injectors and where can I get them?
Old 12-06-2007, 06:31 PM   #8
Supra2NR
Supra2NR's Avatar
550cc bigger injectors, more fuel
an upgrade from the 440cc that comes stock with the motor
RC, Venom, a few companies that make injectors
Old 12-07-2007, 05:24 PM   #9
Spudboy
Spudboy's Avatar
What about this Lexus AFM thing. I assume it's 'Air Flow Meter' which attaches on the air intake...but do I need it with the 550 cc injectors?
Old 10-03-2009, 08:36 PM   #10
dupra87
dupra87 is on a distinguished road
Default ?
what type of lexus
dupra87 is offline   Reply With Quote
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
