Old 11-13-2007, 09:55 PM   #1
stanley2001
stanley2001 is on a distinguished road
Default Anyone ever try cracked block fixer like Irontite?
I just had a new head gasket installed and head rebuilt on my 1991 Supra turbo. Runs like a charm, lots of power, but coolant is slowly disappearing. Yes, whitish steam comes out the tailpipe when it first starts up. It uses about a cup of coolant every 250 miles.
Has anyone tried using this fix the crack stuff you put into your radiator? like Irontite? Does it work on high powered engines like the 1991 supra turbo that I have? Thanks, Stan
stanley2001 is offline   Reply With Quote
Old 11-15-2007, 01:13 AM   #2
j3pz
i would never put a stop-leak-solution in my radiator. it may fix your problem and you have just as much of a chance of it creating another. wouldnt want it clogging the radiator or any water lines do you? you can try that, tearing your engine apart, or put a cup in every 250 miles
Old 11-15-2007, 04:19 AM   #3
CyFi6
white steam is perfectly normal on startup and for another 5-10 mins, it could be working air out of the system since the job was done. Do you have any visible leaks anywhere? I would pressure test it, and see if its leaking externally, sometimes a car will leak only when driving or its so small that you dont get any drips during the time you spend looking for them. Get a pressure tester on it and see if its leaking anywhere externally, if not take it back to whoever did the headgasket and have them fix it if they did it wrong
Old 11-15-2007, 04:31 PM   #4
IHateHacks
IHateHacks's Avatar
Did they replace the head bolts or reuse them?
Even if they used ARP moly lube at 58ft/lbs it is not enough. They probably used motor oil.
Sounds like you have a choice of tearing it apart now or using that instant blown motor in a bottle and tearing it apart later with a bigger bill.
Old 11-16-2007, 02:28 AM   #5
CyFi6
I wouldnt jump to conclusions, always test the system before doing anything else. its a million times easier and cheaper, and youd feel like shit if you did all the headgasket stuff over and it still did the same thing.
Old 11-16-2007, 06:11 AM   #6
supramacist
supramacist's Avatar
The problem has always been that the majority of the crack sealants break down when they come into contact with coolant.
It's rebuild time however you look at it. Unless you sell it. Wich you may get lynched for after the new owner figures it out.
Old 11-16-2007, 03:39 PM   #7
stanley2001
Default Thanks guys - Problem solved
I just kept topping off the radiator and after 4 times and 300 miles later, it is holding. But I was curious if any of this block and head sealer stuff works. Hope I never have to find out. Thanks again, this is a great Supra site, very helpful.
Stan
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
Cracked Block carfanatic89 MKIII Supra 0 06-16-2007 10:30 PM
