Old 11-17-2007, 09:06 AM   #1
tokis
tokis is on a distinguished road
Default where is the mk3 computer located?
I have a 87 turbo'd supra. And was wondering where is the computer is located at? what do i have to take out?
tokis is offline   Reply With Quote
Old 11-17-2007, 09:27 AM   #2
Supra2NR
Supra2NR's Avatar
take off the glove box
then after that there will be a plastic cover
remover that
and the ecu should be in front of you after that
Old 11-17-2007, 09:32 AM   #3
tokis
thanks alot.. do you know what the different between the JDM 7mgte and the one here? which one is better?
Old 11-17-2007, 10:43 AM   #4
west_side_supra
west_side_supra's Avatar
mmm the JDM might not have a speed limiter, i dont know but i'd be thinking there the same
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-19-2007, 03:48 AM   #5
Supra2NR
Supra2NR's Avatar
the jdm motor has the heatercore hose going out the turbo side
and the hole for the egr valve is plugged on the intake side
mine ddnt come with the oil cooler setup
and my oil filter mounts straight to the block
not in a slant like my old 7mgte came with
where is the mk3 computer located? tokis MKIII Supra 1 11-17-2007 10:41 AM
Anti Theft Computer Questions SupraSaver87 Non-Generation Specific Questions 0 06-23-2006 12:51 AM
