Old 11-24-2007, 09:44 PM   #1
tokis
tokis is on a distinguished road
Default Master reuild kit!!
Well I'm planning to rebuild my motor. So i came across this Master rebuild kit, but dont know if its a good kit. Has anyone tried this kit of heard of it?
http://www.enginepartsstore.com/servlet/Detail?no=565
tokis is offline   Reply With Quote
Old 11-24-2007, 10:17 PM   #2
west_side_supra
west_side_supra's Avatar
well thats pretty sweet little kit, but if you are wanting any performance that isnt the way to go, as for what i would buy extra, greddy timing belt, ARP head bolts/studs, and the HKS MGH. now i didnt see if it came with any pumps like the oil/water/power steering ect.. but other than that i'm using the same bearings :P thats really about it
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 11-25-2007, 12:31 AM   #3
tokis
I not trying to go to extreme. Just around 300 to 350 rwhp it does come with a new oil pump. But for the rest i got it, but whats a HKS MGH? is that kit a OEM stock part?i dont want know cheap aftermarket one
Old 11-25-2007, 02:21 AM   #4
supramacist
supramacist's Avatar
You may be in over your head dude.
An mhg= metal head gasket
hks= brand of metal head gasket.
Not the cheapest shite around.
My 2.mm hks stopper mhg was right around 350 cash.
You need to do some research urgently.
Because this is a real good way for you to waste a car, not knowing what you are doing,
www.horsepowerfreaks.com
These guys have everything you need except for the torque wrench.
Old 11-25-2007, 07:41 AM   #5
west_side_supra
i got my stopper for 150$ EBAY !!! lol its da shit. acually i think i have gotten almost everything through ebay and have probably saved about 2k$ i think the most expensive stuff i got were the JE pistons and eagle rods and the HKS EVC. other than that everything was almost 30%-50% off the retail prices. but i have ordered a couple things trough HPfreaks "turbonetics manifold and some hose's" and also Supra sport has been very nice also.
fidenza cam gears
Old 11-26-2007, 08:14 PM   #6
supramacist
Everytime I order something from ebay wich has been twice someone takes my money and I get no parts. I avoid that place like the plague.
Old 11-28-2007, 06:02 AM   #7
west_side_supra
i've gotten almost everything through ebay for my motor. i have never had one problem through them and i always use paypal so that way i can take my right on back if they do try to screw me over :P
fidenza cam gears
Old 11-28-2007, 06:54 AM   #8
tokis
well my question is that master kit an OEM part? or some cheap aftermarket one. Has anyone try using this kit before? i just want to get OEM parts
Old 11-29-2007, 03:59 AM   #9
supradaddy0803
supradaddy0803's Avatar
To answer your question yes it is stuff up to a OEM standard. I used a master kit a long time ago to rebuild my 7MGE on my 86.5 and it had everything needed to get back to OEM. One problem though I would say go the Metal head gasket and ARP stud route you will save yourself a headache when your head gasket blows. Plus for your 350 hp goal it will leave you the availablity to go higher if you want. But just remember if you havent done a engine rebuild do a ton of research before you start the guys one here arent trying to smash you down just warning you and trying to keep another supra on the road is all.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
brake master cyl. tak2099 MKIII Supra 2 08-19-2008 11:27 PM
Master rebuild? h8z2luze MKIII Supra 5 05-22-2007 05:16 AM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
