Old 11-27-2007, 12:30 PM   #1
suprakid91
suprakid91's Avatar
suprakid91 is on a distinguished road
Default new problem
so every now and then after i get past 4000 rpm and press the clutch to the floor it dips below 500 rpm and dies most of the time. i have no idea what to even start with. what do you guys think it could be?
91' 7m-gte, sold
suprakid91 is offline   Reply With Quote
Old 11-27-2007, 01:11 PM   #2
abhattan
abhattan's Avatar
abhattan is on a distinguished road
First off, is the check engine light on? Do you have any codes? Then we'll take it from there.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 11-27-2007, 02:16 PM   #3
IHateHacks
IHateHacks's Avatar
Boost leak.
Are you running a stock BOV or one that dumps to atmosphere?
Old 11-27-2007, 09:14 PM   #4
suprakid91
suprakid91's Avatar
no. the check engine light is off and i have no codes. and i dont have anything. no bov or anything. just whatever comes stock on the gte.
91' 7m-gte, sold
Old 11-28-2007, 04:36 AM   #5
f00g00
If your normal idle is OK then its probably your Dashpot incorrectly set or running too rich.
Old 11-28-2007, 04:40 AM   #6
suprakid91
suprakid91's Avatar
my normal warmed-up idle is about 6-700 rpm. and what exactly is a dashpot?
91' 7m-gte, sold
Old 11-28-2007, 10:31 PM   #7
f00g00
Check it here and go to page EC-8
http://www.turboninjas.com/mk3supra/...ndiv/06_EC.pdf
When you decelerate, its supposed to partially open the throttle more than at idle to get a complete burn. If for example it isn't working at all you could a too rich situation that might bog it down. Just set it to factory specs and see how it goes.
Old 11-29-2007, 12:35 PM   #8
suprakid91
suprakid91's Avatar
ok thanks. i will tell you how it goes when i get it done.
91' 7m-gte, sold
Old 11-30-2007, 01:42 AM   #9
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
check all your vacuum lines also... my guess is it's a leak
Pics of my build.
Do a diagnostic first!
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
