Old 11-28-2007, 02:01 AM   #1
tokis
tokis is on a distinguished road
Default Idle problem
well I got my car running again. BUT i ran into another problem, my car 87 turbo supra is Idling lil above one. I dont think it suppose to be that high i believe. AND my idle screw is screw'd in all the way!! any help??
tokis is offline   Reply With Quote
Old 11-29-2007, 04:06 AM   #2
supradaddy0803
supradaddy0803's Avatar
Well for starters screwed all the way in or out. That will make a difference because out is slower and in is faster. Also do a check in the Online manual on here for the test for the Idle speed control valve, the adjustment for the Throttle position sensor, and the proper adjustment of the idle screw. Hope that helps I dont deal with 7MGTE very much so I dont know it off the top of my head. If it was a 1JZ I could tell you quick.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-29-2008, 01:00 AM   #3
3.0trd
3.0trd is on a distinguished road
I was having the same problem with my na, I didn't play with the idle screw so I would suggest setting that back to factory, and replace your tps. granted I have the na, but I bet that will fix it. check your timing also, advanced timing will jump the idle.
Cometic MHG, ARP studs, H&R lowering springs
3.0trd is offline   Reply With Quote
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
