Old 11-29-2007, 06:03 PM   #1
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
Default ok i have a question
i am going to be taking 2 7mgte engines out of my cars. one im gonna be racing. then one im gonna be rebuilding i dont wanna spend the kinda money on both but i do wanna do it right. im gonna replace the racing engine with a hks hg and arp hbs but on the other one im gonna leave the stock head bolts. what kinda gasket do you guys think i should go with because the hks is like 100 and something bucks. and what tourque has some of you guys gone with????
please let me know ill be starting this project in about a month after i get my honda's engine replaced. so i can have a daily driver
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
tsupra89 is offline   Reply With Quote
Old 11-29-2007, 09:16 PM   #2
j3pz
dont reuse the headbolts. if you dont wanna buy two sets of arp's then atleast get a set of oem's. the arp's will say what to torque to, i think its something around 80 or maybe higher, and the oem's will suggest like 56 but we all know thats bs. if you get a metal hg make sure the block surface is smoothed enough, i dont the number off the top of my head but im sure with a lil searching it can be found. if the block surface isnt smooth enough, the mhg wont seal right and will result in a bhg.
Old 11-30-2007, 12:20 AM   #3
tsupra89
tsupra89's Avatar
alright thanx man and i dont know what arp headbolts run i havent priced them but i might just hks hg and arp hb both of them because it will only be 200 bucks and both be strong as no other
lexus afm
k&n air system
walboro fuel pump
apc hood pins
yellow fogs
Soon To be
Old 11-30-2007, 01:30 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
what are you planning to do with the non racing one?
A "new" stock hg & headbolts last fine up to 300 odd whp and the only reason this particular engine blew it's hg was from the detonation. So as long as it's bolted down to 72 for stockie or 80-85 for arp (as said, it'll be written somewhere in the instructions) The engines are all good.
Oh yea, as said above, make sure you get the block & head smoothed to the correct RA
I managed to get mine down to 17 RA which is really quite good so i won't have sealing issues
Pics of my build.
Do a diagnostic first!
Old 11-30-2007, 03:32 AM   #5
ethan12510
ethan12510 is on a distinguished road
u should get Apr head studs you can reuse them i belive
ethan12510 is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
