-   -   Thermostat (http://www.toyota-supra.info/forums/mkiii-supra/10278-thermostat.html)
SilenceboneSupra 12-01-2007 01:35 AM
Thermostat
Hi i was working on the timing of my car and replacing water temp sensors when i noticed i was missing the thermostat but now i am wondering what is the thermostat's purpose and do i realy need it?
Thanks
CyFi6 12-01-2007 05:26 AM
The thermostat uses the temperature of the coolant on the engine side to decide how far to open, its a valve. The more coolant it flows, the more goes through the radiator=the cooler the engine runs. For everything to work properly you NEED a thermostat, you will get weird issues with gas mileage and things like that without a thermostat, its possible to overheat without a thermostat because coolant travels through the radiatior so fast that it doesnt have time to cool. Install a thermostat.
SilenceboneSupra 12-01-2007 06:37 AM
when i bought this car i installed a oil temp sender and the oil temp always seemed a bit high but i never knew the car was missing the thermostat, the water temp sender didn work sow i couldn see if the engine was overheating or not. thanks :gotnos:
