Old 12-04-2007, 10:40 PM   #1
Supra Noobie
Supra Noobie is on a distinguished road
Default Car Chokes
I have a 87 Supra. i have changed the plugs, wires, fuel filter, ait filter, put a boost controller on it . after market boost gauge, k&n filter, the engine is a import that has less than 30k on it. pluged most of the leaks. cleaned the throttle body, and i hear the turbo spool and it sucks air very loudly, but starts chokeing and starts to die in the process. and my boost gauge reads 0 the whole time. i could use any input and any help offered. i have a lot of money into this car and i want to finish it but i am at a loss on what to do.
Any one that lives in kansas and would offer help i would be very much abliged
Matt
Supra Noobie is offline   Reply With Quote
Old 12-05-2007, 04:13 AM   #2
jfunez
jfunez's Avatar
sounds like a boost leak......check your intercooler piping clamps.. also check the plastic pipe that is hidden in the passengers front fender...
Old 12-05-2007, 04:14 AM   #3
jfunez
jfunez's Avatar
you wouldn't happened to clean the MAF sensor with tb cleaner did you?
Old 12-05-2007, 03:27 PM   #4
supradaddy0803
supradaddy0803's Avatar
Also sounds like you have your boost controller set to high. When you put it in did you make sure that you connected the hoses off the wastegate the correct way. If you get them backwards then you will not get anything but the wastegate open all the time and no boost which sounds like what you have going on. Plus it is a good way to know something you added did it when it happened after you put the boost controller.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 12-06-2007, 07:09 PM   #5
Supra Noobie
Actually the Car ran fine until the hose for the blow off valvecame off then since i fixed the blowoff valve line with a new hose it has been doing this
Old 12-06-2007, 09:50 PM   #6
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i would say you hit some high boost and blew off a pipe a good'n
you have a pipe "off" somewhere... 0 on the gauge means massive leak
i assume it idles very bad and stalls all the time?
Pics of my build.
Do a diagnostic first!
Old 12-06-2007, 10:32 PM   #7
Supra Noobie
It idles fine and then as soon as there is a load on the engine. puting it in first and trying to drive down the road. it starts choking and dieing
Old 12-06-2007, 10:45 PM   #8
suprra_girl
7M POWAH! ;)
check your intercooler pipes from turbo to throttle body
Pics of my build.
Old 12-07-2007, 05:22 AM   #9
Supra Noobie
thanks for all the help so far. i will check them on sunday night or monday. cause that is the first time i will have a chance
Old 12-07-2007, 08:45 PM   #10
88Tsupra
88Tsupra is on a distinguished road
I agree with supra gurl. Does sound like a IC leak somewhere.
I had a guy I know blow off a coupler and this car completely shut off on him. And that was on a 1j
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
