Old 08-19-2009, 12:12 AM   #1
judodude64
judodude64 is on a distinguished road
Question Car starts then dies. Starts then won't start
Just bought a 88 turbo two weeks ago. Ran perfect when I bought it. Or so I thought. Drove it fine for a week.
After I filled up the gas tank it would not start. Let it sit for a week and then it started up but wouldn't idle and stall whenever I let the rpms drop. The car still seemed to have 100% power when I pushed it. Brought it back into the garage changed the spark plugs, coolant and oil just for good measure.
After I did that I starting up to make sure I put everything back together again properly. (spark plug job is a pain in the ass) Ran for five minutes and then I turned it off so I could take it off the jack stands. Went to start again to drive around a while and I wouldn't start again.
Starters working great. Even sounds like there might be an ignition every once and a while but won't take Hold.
Does anyone have advice about what I should check next?
judodude64 is offline   Reply With Quote
Old 08-19-2009, 06:58 PM   #2
chaos99
chaos99's Avatar
chaos99 is on a distinguished road
I'm new to these cars, but when I had a similar problem a couple weeks ago, I had to adjust my cam pos. sensor, like it was out of time, I also found if when it is running, if i touch the wires on the cps, it dies. Basically I retarded my timing a hair so it will start easily until I replace the cps. still runs fast and smooth.
'87 Supra Turbo Auto
new HG w/ ARP bolts 82lbs
Titan 3" DP
5 washer shim on Wastegate
still have alot of work to do.
chaos99 is offline   Reply With Quote
Old 08-20-2009, 12:27 AM   #3
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
please read your bible.
http://www.cygnusx1.net/supra/library/TSRM/index.html
shiftysupra is offline   Reply With Quote
Tags
advice, idle, ignition, stall, start
starts but then dont start dieseltech24179 MKIII Supra 8 11-29-2008 09:27 PM
only starts by jump start ItsnotmySupra MKII Supra 6 04-27-2008 03:14 AM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Start up and engine dies. Drag0na5h MKIII Supra 12 01-14-2007 02:04 AM
mkIII probs, starts then dies and then not at all katillidie MKIII Supra 3 03-30-2006 08:24 AM
