Old 12-05-2007, 11:58 PM   #1
jcgrant4
jcgrant4 is on a distinguished road
Default No spark mystery on 7mgte
I've lost spark on my 88 7mgte and have hit a wall in my diagnostics. I've got 12v at the 3 coil pack connectors and the ignitor, the resistance on the cps connector pins is all good, but no spark. I tried a back up coil pack, no help. The one thing I can't figure out how to test is for the signals the ignitor sends to the coil packs to fire the plugs. Any ideas? TIA
Jim G
jcgrant4 is offline   Reply With Quote
Old 12-06-2007, 10:07 AM   #2
have you tried wiggling the cps plug?
what codes have you got?
Old 12-06-2007, 12:44 PM   #3
jcgrant4
No codes - I haven't had it started since disconnecting the battery to clean the terminals & check the cables. I'm suspicious of the cps plug/wiring after reading the tons of other posts on this topic, so I'll check that out next.
Old 12-06-2007, 09:24 PM   #4
jcgrant4
Okay, cps connector/wires look good, so I decided to check the cps terminals at the ecu. Found 3 plug wasn't seated tight. Now I get spark, but it's weak & intermittent. BTW - the cps did test good at the ecu connector, so now what - ignitor?
Old 12-06-2007, 09:49 PM   #5
the cps wires directly at the cps plug generally naff out
usually a good wiggle will get the car going again
Old 08-19-2009, 03:57 PM   #6
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
hey I have this problem. did you ever figure it out?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
7mgte swap no spark supra4life1386 MKIII Supra 5 11-27-2008 07:57 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
